• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Drew Burgasser
    Civil 3D 2005 Installer pops up
    76 Views, 6 Replies
    12-07-2004 04:10 PM
    When launching the following software, the Civil 3D 2005 Installer pops up: Sema4 v8.3.1 made by Deltek Systems, Inc. This is a Foxpro timesheet program If users are temporarily granted admin privileges, the installer does what it needs to do and goes away. If admin privileges are then taken away, the problem reappears. There are about 200 users, so it's a pretty ugly problem. Thanks, Drew Burgasser CAD Masters, Inc.
    Please use plain text.
    *John Meyer Consulting \(Rob Aiello\)
    Re: Civil 3D 2005 Installer pops up
    12-08-2004 09:58 AM in reply to: *Drew Burgasser
    I am having the same issue with a number of programs, including MS Outlook and our plotting software, KIP Request. Any ideas? Thanks, Rob "Drew Burgasser" wrote in message news:41b645c5$1_2@newsprd01... > When launching the following software, the Civil 3D 2005 Installer pops > up: > Sema4 v8.3.1 made by Deltek Systems, Inc. > This is a Foxpro timesheet program > > If users are temporarily granted admin privileges, the installer does what > it needs to do and goes away. If admin privileges are then taken away, > the problem reappears. > > There are about 200 users, so it's a pretty ugly problem. > > Thanks, > Drew Burgasser > CAD Masters, Inc. >
    Valued Contributor
    12-23-2004 08:31 AM in reply to: *Drew Burgasser
    same problem here when starting INSTALLSHIELD
    very annoying !!!
    Valued Contributor
    12-23-2004 11:21 AM in reply to: *Drew Burgasser
    It happens to me when I bring up ArcMAp. If I have any acad.exe program running it won't finish until I close it AutoCAD. What a pain!
    Active Contributor
    02-15-2005 03:39 AM in reply to: *Drew Burgasser
    I had the same problem after I loaded a trial version of Carson 2004, so I ended up uninstalling Carson. Now I have it in AutoCAD. The common links are the autoCAD engine and the (in my case, MS Outlook.
    I hope someone has a fix.
    Distinguished Contributor
    ACADuser
    05-18-2005 08:12 AM in reply to: *Drew Burgasser
    Hi Drew,
    Did you ever find a solution to this ?
    ACADuser
    Dell Precision T5500 Workstation
    Windows XP Professional SP3
    Dual Quad Core Intel Xeon Processors E5540 2.53GHz,8M L3,5.8GT/s,turbo
    4GB, DDR3 Memory, 1066MHz, ECC (4 DIMMS)
    1.5GB NVIDIA Quadro FX 4800, DUAL MON, 2DP & 1DVI
    160GB, 3.0Gb/s, 16MB Data Burst Cache,SATA2,10K RPM Hard Drive
    16XDVD AND 16XDVD+/-RW
    05-18-2005 01:31 PM in reply to: *Drew Burgasser
    I was having similar problems. I uninstalled C3d 2005 before installing 2006, (and made sure to manually wipe out any remaining trace of 2005 that I could find). Haven't had any problems since then (so far...)
