• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Civil 2012 Draworder
    492 Views, 2 Replies
    08-15-2011 05:44 AM
    Has anyone had issues with the draworder command from the the toolbars and/or icons not working. I get this message:
    Command:  Unknown command "AI_DRAWORDER".  Press F1 for help.
    Command:  Unknown command "FRONT".  Press F1 for help.
    FYI - I installed the new Suites Package containing Autodesk civil 3d and regular AutoCAD. In Autocad it works fine, but in Civil is does not work. I have read some post about it being a "dorder.arx file" issue, but I can not find the file in either locations for AutoCAD and AutoCAD Civil.
     Troy Moore, PE
    AutoCAD Civil 2012
    Troy Moore
    Civil3D 2012
    Windows 7 Pro, 64 bit
    Intel Xeon E31225 @ 3.40Ghz
    16 GB RAM
    Please use plain text.
    Re: Civil 2012 Draworder
    08-15-2011 09:34 AM in reply to: troymoore7595
    I have no problems with any of them.
    Bill
    Product Support
    AlmasSuljevic
    08-17-2011 10:46 AM in reply to: troymoore7595
    Hi Troy,
    I also don't have any issues with any of DRAWORDER commands. Any chance you have custom CUI loaded. Can you try typing DR for draw order and see if that works? Check your CUI editor, look for draw order command and see what macro says. You should see something like this:
    Almas Suljevic
    Product Support Specialist
    Autodesk Global Subscription and Support
    Please click on "Accept as Solution" if post helped you resolve the issue.
