• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Joe-Bouza
    Check this out
    315 Views, 9 Replies
    12-14-2011 03:37 PM
    I was Gading and went to save: If anyone knows how to fix that Id be happy to hear.
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Please use plain text.
    Re: Check this out
    12-14-2011 04:05 PM in reply to: Joe-Bouza
    Search for "One or more" and you will find this has been an issue for a quite a while.
    Some, including me, have had luck with Audit and then Save immediately afterwards.
    Joe-Bouza
    Re: Check this out
    12-14-2011 04:17 PM in reply to: Jeff_M
    Thank you good sir. Surprised I have not seen it yet. Is it more common with gradings?
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    Neilw
    Re: Check this out
    12-14-2011 07:06 PM in reply to: Joe-Bouza
    I just ran into this one today Joe. My dwg has only a couple of surfaces, alignments and profiles, so it can't be related to gradings. I noticed when it happened that C3D was creating a new temp file in my project folder with each failed save. I got past it by save-as to a new file.
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    AllenJessup
    Re: Check this out
    12-15-2011 05:42 AM in reply to: Joe-Bouza
    Joe. As mentioned, this has been a problem for a while. See this  thread and the link in there (by me).
    I've had to do multiple Audits at time. I even have a macro that will do 10 in a row. If this continues, about the only thing you can do is to try and wblock out your drawing and insert it in to a fresh one from your template.
    It's not just specific to grading. It seems at some point something breaks in a Civil 3D drawing and can't be fixed. Why don't you start a SR and remind Autodesk that it's still an issue.
    Allen
    johnm
    Re: Check this out
    12-15-2011 06:37 AM in reply to: Joe-Bouza
    Not sure if it's linked to gradings but I typically see this in files with too many FL's that have an overload of elev pnts and/or PI's and when I have too many files open in one session.  Perhaps is just PC mem overload...
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    Joe-Bouza
    Re: Check this out
    12-15-2011 12:11 PM in reply to: Joe-Bouza
    Thanks for the input gents. All good advice to look out for.
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    Distinguished Contributor
    Re: Check this out
    12-15-2011 12:40 PM in reply to: Joe-Bouza
    I ran into this a couple of weeks ago after installing SP1 and it wouldn't let me audit or purge. Finally had to exit without saving. I sent a support request to Autodesk there response was as follows:
    Thank you for contacting Autodesk Support. I went through your query and the update you have sent. The error message "One or more objects in this drawing cannot be saved to the specified format" has been associated with couple of reasons:
    Either corruption in the drawing for which, you can run RECOVER, though AUDIT and PURGE are not working at your end.  If you find that you still cannot save the drawing, try selecting everything and then use WBLOCK to write a new drawing from the selected objects. You might also try copying the selected objects (Ctrl+C, the copyclip command, not AutoCAD copy) and pasting them into a new drawing created from scratch.
    I have seen this a couple of times since but have been able to audit and save.
    Cory
    Civil 3D 2013 SP1
    Win 7 x64 SP1
    Intel Core2 Duo 2.67 GHz
    8 GB RAM
    NVIDIA Quadro FX 3500
    Re: Check this out
    03-29-2012 05:10 PM in reply to: cbess
    I have just been hit with this at the 11th hour. My C3D 2011 won't save any file, even the blank drawing at start up. My work files will save on other computers but not mine...so I think I did something to my installation... Auditing does not seem to help the situation.
    It all started when I tried to open a "Previous Version" of a file from Explorer.
    Re: Check this out
    04-16-2012 12:41 PM in reply to: blenz
    I unistalled AutoCAD Civil 3D 2009, and Civil 3d 2011 went back to working. Go figure.
