AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Change of Station Label Format
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I would like to change the station label format from 00+000.000 to 00,0+00.000
To move the + is easy, but how can I add the ,?
This type of station label is the standard by the Deutsche Bahn, so it's not that far-fetched.
thx.
Christoph
HP z400 Workstation
ATI FirePro V4800
C3D2013
Re: Change of Station Label Format
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You could add a text component containing the comma and position it between the digits. However. I can't think of any way to create a space. So it would look pretty clumsy. See http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Lin
Allen
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
People have accomplished something similar for dimensions. I wonder if that would work here.
http://forums.autodesk.com/t5/AutoCAD-R12-R13-R14-
http://forums.autodesk.com/t5/AutoCAD-2013/Thousan
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It won't work with the digit grouping option - This Option is not available for Station-Formats.
I solved the Issue then via:
1. Create a new Expression "00,0": Rounddown(Stationvalue,-3)/1000
2. Adress this into your Styles: "00,0" "Station-Index-Sign" "Station Index left side of the Station-Index sign.
Thx.
HP z400 Workstation
ATI FirePro V4800
C3D2013
