AutoCAD Civil 3D
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Change default structure of Project folders
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
51 Views, 2 Replies
05-26-2005 04:26 PM
Is there a way to change the default folder structure of projects? We really don't need all those folders, in fact they would really just get in the way. We would rather have one folder for "Data." That's it. I really don't even want to use projects, but apparently there's no way to use data shortcuts without projects (contrary to what's been advertised). All we want to do is be able to separate the data from the every-day drawing work; and keep our organization SIMPLE. Thanks.
Kevin Currey
Kevin Currey
Re: Change default structure of Project folders
Options
- Highlight
- Email to a Friend
05-27-2005 12:18 PM in reply to:
kevincurrey
Hi Kevin,
Outside the project environment, you can create data shortcuts using the Data Shortcut vista. (General > Data Shortcuts > Edit Data Shortcuts).
To make a data shortcut available to other drawings, you then export it.
Jonathan Burgoyne
Jonathan Burgoyne
Options
- Highlight
- Email to a Friend
05-27-2005 12:47 PM in reply to:
kevincurrey
Is there a way to make the shortcut stay referenced after a file has been closed? If I have a drawing with a data reference in it, the reference disappears the next time I open the file. I have to re-import the shortcut, then synchronize.
