• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    johnm
    Re: Centerline from Buffer
    02-13-2013 10:51 AM in reply to: Vasily_BC
    The Join and Weed Feature Line command or Mapclean can be used to get rid of most of those verticies and make a single pline. If you do this the offsetting and other operationsshould perform much better.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    Please use plain text.
    *Expert Elite*
    johnm
    02-13-2013 10:54 AM in reply to: johnm
    If these operations take too long or dog the machine down, then perform the operations on small portions of the buffer. Working with segements of the data will speed you up and you can join the segements together to finish.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    Active Contributor
    02-13-2013 11:05 AM in reply to: johnm
    Another method maybe.
    1. Create a surface based on sides of ROW.
    2. Create contour lines.
    3. Extract contour lines.
    4. Find proper one.
    It could be very good technique, but triangulated surface is nor ideal and needs time for correction.
    *Expert Elite*
    BrianHailey
    02-13-2013 07:49 PM in reply to: Vasily_BC
    Can you share the file? I have some ideas that I want to try on it.
    Active Contributor
    02-14-2013 12:11 PM in reply to: johnm
    Sure.
    *Expert Elite*
    antoniovinci
    02-14-2013 01:25 PM in reply to: Vasily_BC
    I concur with Alfred's solution: check this out (more exactly, the animation of 2012/09/17 20:30 post).
    Active Contributor
    02-14-2013 02:26 PM in reply to: antoniovinci
    The thing is that offset to within doesn't work. Maybe because AutoCAD can't find its center?
    *Expert Elite*
    BrianHailey
    02-16-2013 08:22 PM in reply to: Vasily_BC
    Here's the problem, you have 15 gazillion verticies (yes, I counted) on that buffer because of the way it was created (i.e. no curves). When doing anything with that, it's going to bomb out on you so get rid of all the little segments.
    HERE is my solution.
    *Expert Elite*
    02-18-2013 08:59 AM in reply to: BrianHailey
    Hello Brian,
    You solution works for parallel offsets, but what happens when the two sides of your figure are not parallel? How do you ensure your new polyline is centered between points at a particular station?
    Tim
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
