• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Mentor
    fcernst
    Catchment - Flow path segments travel time inot labeled correctly
    69 Views, 4 Replies
    11-27-2012 05:12 AM
    Flow segment label using total Flow Type travel time for each segment:
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
    Please use plain text.
    Product Support
    AlmasSuljevic
    Re: Catchment - Flow path segments travel time inot labeled correctly
    11-28-2012 08:14 AM in reply to: fcernst
    Hi Fred,
    Can you provide us more information on the issue and if necessary your drawing? Also, did you try editing your Label Style and see if you can remove Time component from label.
    Almas Suljevic
    Product Support Specialist
    Autodesk Global Subscription and Support
    Autodesk, Inc.
    Please click on "Accept as Solution" if post helped you resolve the issue.
    Valued Mentor
    fcernst
    Re: Catchment - Flow path segments travel time not labeled correctly
    11-28-2012 08:26 AM in reply to: AlmasSuljevic
    Hi Almas,
    Yes I can remove the label, but I don't want to...
    I want it to correctly label the two flow segments with 1.68 min and 0.45 min.
    I have attached the file.
    Ernst Engineering
    Fred Ernst, PE
    Product Support
    AlmasSuljevic
    11-28-2012 08:52 AM in reply to: fcernst
    I see what you are saying now. By researching I found that this is already reported to development.
    Almas Suljevic
    Autodesk, Inc.
    Valued Mentor
    fcernst
    11-28-2012 08:55 AM in reply to: AlmasSuljevic
    Thanks. How long ago was this reported?
    Ernst Engineering
    Fred Ernst, PE
