Civil 3D Forum
Catchment Area Enhancements
4 REPLIES 4
el_nath
773 Views, 4 Replies
I wish to have the ability to define runoff coefficient regions of a surface (using parcels, closed polylines, aecpolygons, mpolygons, etc...) such that when a catchment area is created, the weighted runoff coefficient is calculated. For a corridor surface, the runoff coefficient can be specified by the link code used to define the surface (defined in the code set style).
These surface coefficients should continue through pasting operations, i.e. a final design surface should have the runoff coefficents from the various corridor and grading surfaces used to define it.
Currently, I have to manually calculate the weighted runoff coefficient by first determining grass, aphalt, roof, areas per each catchment area.
Nathan Selles-Alvarez, P.E.
Senior Civil Engineer
4 REPLIES 4
cpennetti
in reply to: el_nath
I think that would be a huge help as well. Some sort of cover condition could go a long way I'm Civil 3D to adding intelligence to the model, including assigning cover parameters to surfaces... that would really start to make it more of a "BIM" system
fcernst
in reply to: cpennetti
Yes, along with %impervious, SCS curve numbers, N-imperv/Perv and D-Store Imperv/Perv.
Multipurpose these defined surface areas: There should be an additional database field for surface material thickness that can be used to define the subgrade datum for earthwork calculations.
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Lisa_Pohlmeyer
All of you should post this to the Wishes discussion group!  Also, on the AUGI wish list.
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
el_nath
You know I thought I did post this on the wish list. My bad (and working far too late!)
Rail Community
