• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Cant find Survey-4B.dwg
    114 Views, 5 Replies
    01-10-2013 12:48 PM
    Where is it?  I find the tutorial for it, thats as far as I get
    Please use plain text.
    Valued Mentor
    Re: Cant find Survey-4B.dwg
    01-10-2013 12:59 PM in reply to: pete1rya
    It is usually in this path (differs per your version) C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\Help\Civil Tutorials\Drawings
    HTH
    AWood
    Member
    i do that and I use the help tool and I get to where it s...
    01-10-2013 01:04 PM in reply to: awood
     i do that and I use the help tool and I get to where it states the location, than what?
    Member
    Survey-4B.dwg
    01-10-2013 01:10 PM in reply to: pete1rya
    when I get to the help location, there is nothing there to click and nothing that says Survey-4B. dwg
    Am I missing something critical?  I need help
    TRogers
    Re: Survey-4B.dwg
    01-10-2013 01:32 PM in reply to: pete1rya
    Upon installation, if you didn't do the "custom" install and select for the Sample files to be extracted from the install, you won't have them.
    If the issue was resolved by this method, please click on "Accept As Solution"
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    Re: Survey-4B.dwg
    01-10-2013 01:36 PM in reply to: pete1rya
    You should be seeing something like this in Windows Explorer.
    Bill
