• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Accepted Solution
    Can't offset a horizontal alignment to create a pline
    311 Views, 10 Replies
    12-19-2012 09:44 AM
    This is with Civil 3D 2013.  I am able to create a pline by offsetting an alignment using any drawing on any other workstation in our office, but on my machine I get an error: "1 object(s) were filtered out." when I try to select the alignment.
    This leads me to searching for some system variable or something that is different on my machine.  Has anyone else come across this?
    Thanks.
    Please use plain text.
    *Pro
    Re: Can't offset a horizontal alignment to create a pline
    12-19-2012 10:00 AM in reply to: fcopley
    reboot, and reload?
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    *Expert Elite*
    12-19-2012 03:57 PM in reply to: fcopley
    I'm going to guess that you're selecting not the alignment, but something on top of it, like the station labels, by accident.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    *Expert Elite*
    12-20-2012 06:44 AM in reply to: fcopley
    Any locked layers in the drawing?
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Active Member
    12-20-2012 07:48 AM in reply to: fcopley
    Thanks for all the suggestions, but none seem to make a difference.  Time for a proper wipe and reinstall, I guess.
    *Expert Elite*
    12-20-2012 08:08 AM in reply to: fcopley
    There are a few other error finders I would try.  You say this is only one machine; is it also only one drawing, or any alignment in any drawing?  What happens if you log into windows as different user?
    Active Member
    12-20-2012 08:40 AM in reply to: troma
    That does narrow it down.  It works fine logged in as another user on my machine.  It seems to be any alignment in any drawing.
    Thanks.
    *Expert Elite*
    12-20-2012 08:45 AM in reply to: fcopley
    What do you get if you log into windows as yourself and then choose a different C3D profile in the options dialogue?
    Active Member
    12-20-2012 08:54 AM in reply to: troma
    It seems to be the same using any profile.
    But I did just realize that it will in fact work for me if I select the alignment first and then issue the offset command.
    Thanks.
    Active Member
    12-20-2012 09:03 AM in reply to: troma
    Okay, I sort of solved this by overwriting some of my user files in \AppData\Roaming\Autodesk\C3D 2013\enu from another user.  I would still like to have a better idea of what caused it.
    Thanks, troma for your suggestions.
