AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Can't offset a horizontal alignment to create a pline
- Highlight
- Email to a Friend
This is with Civil 3D 2013. I am able to create a pline by offsetting an alignment using any drawing on any other workstation in our office, but on my machine I get an error: "1 object(s) were filtered out." when I try to select the alignment.
This leads me to searching for some system variable or something that is different on my machine. Has anyone else come across this?
Thanks.
Re: Can't offset a horizontal alignment to create a pline
- Highlight
- Email to a Friend
reboot, and reload?
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
6Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
- Highlight
- Email to a Friend
I'm going to guess that you're selecting not the alignment, but something on top of it, like the station labels, by accident.
Cansel - Autodesk Division
http://www.cansel.ca/
- Highlight
- Email to a Friend
Any locked layers in the drawing?
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Highlight
- Email to a Friend
Thanks for all the suggestions, but none seem to make a difference. Time for a proper wipe and reinstall, I guess.
- Highlight
- Email to a Friend
There are a few other error finders I would try. You say this is only one machine; is it also only one drawing, or any alignment in any drawing? What happens if you log into windows as different user?
- Highlight
- Email to a Friend
That does narrow it down. It works fine logged in as another user on my machine. It seems to be any alignment in any drawing.
Thanks.
- Highlight
- Email to a Friend
What do you get if you log into windows as yourself and then choose a different C3D profile in the options dialogue?
- Highlight
- Email to a Friend
It seems to be the same using any profile.
But I did just realize that it will in fact work for me if I select the alignment first and then issue the offset command.
Thanks.
- Highlight
- Email to a Friend
Okay, I sort of solved this by overwriting some of my user files in \AppData\Roaming\Autodesk\C3D 2013\enu from another user. I would still like to have a better idea of what caused it.
Thanks, troma for your suggestions.
