AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Can't label certain pipes/stru ctures
- Highlight
- Email to a Friend
Can someone tell me why I can't label certain pipes/structures? I can select the pipe or structure, rt click, add label and I get nothing. The layer is on cause I can see other labels. I also get the same result when I go to annotation, pipe label. This only happenes to certain pipes or structure, others in the same network label fine. I'm kind of at a loss.
Re: Can't label certain pipes/stru ctures
- Highlight
- Email to a Friend
Is the layer off or frozen?
Is the default label style (command setting) set to None or No Display?
C3D 2012, RD 2012
Win 7 64, Core i7,
6 GB RAM, Quadro FX 1700
- Highlight
- Email to a Friend
No
No.
Again, it's just certain pipes or structures. The pipes and structures in the same profile view just the downstream from the problem ones label fine.
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
Correct, only in profile views. The alignment does not go beyound the structure.
- Highlight
- Email to a Friend
well, if it's the same thing i've seen on my profiles, even when an alignment starts at 0+00 and goes to something like 1+53 from a few structures, you have to set the profile view to something like -0+50 and 2+00 (or some other value beyond the length of the profile) for those end structure and pipe labels to show up.
But, if it's a band thing, you'll want to check the option to show band labels at start and end...
- Highlight
- Email to a Friend
here is what i usually do.
- check to make sure the pipe or structure is tied to an alignment and right on top of the alignment and not offset
- ensure the pipe or structure is tied to a surface
- run a -PURGE then R for regapps
- then audit
- then REA for regenall.
- also check to ensure that you are still pointing to the correct pipes catalog
- if you still can't label the pipe i will do a pipe swap then swap it back to what it was originally.
Tony
CAD Manager
www.tonyscivil3dworld.blogspot.com
- Highlight
- Email to a Friend
Still can't label the pipe. Here is the kicker, I can label the pipe in plan just fine, just not in profile view. Here is what I get:
Select profile view:
Selected entity must be of type: Profile View
- Highlight
- Email to a Friend
Are you selecting the profile view before selecting the pipe?
C3D 2012, RD 2012
Win 7 64, Core i7,
- Highlight
- Email to a Friend
no
