• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    keith.kempker
    Can't label certain pipes/structures
    418 Views, 15 Replies
    03-07-2012 12:57 PM
    Can someone tell me why I can't label certain pipes/structures?  I can select the pipe or structure, rt click, add label and I get nothing.  The layer is on cause I can see other labels. I also get the same result when I go to annotation, pipe label.   This only happenes to certain pipes or structure, others in the same network label fine.  I'm kind of at a loss.
    Please use plain text.
    johnm
    Re: Can't label certain pipes/structures
    03-07-2012 01:10 PM in reply to: keith.kempker
    Is the layer off or frozen?
    Is the default label style (command setting) set to None or No Display?
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    Active Member
    keith.kempker
    03-07-2012 01:11 PM in reply to: johnm
    No
    No.
    Again, it's just certain pipes or structures.  The pipes and structures in the same profile view just the downstream from the problem ones label fine.
    Active Contributor
    cpennetti
    03-07-2012 09:33 PM in reply to: keith.kempker
    Are you saying its a problem with parts in profile views? Does your profile view station go a little beyond total alignment station?
    Active Member
    keith.kempker
    03-08-2012 05:59 AM in reply to: cpennetti
    Correct, only in profile views.  The alignment does not go beyound the structure.
    Active Contributor
    cpennetti
    03-08-2012 06:21 AM in reply to: keith.kempker
    well, if it's the same thing i've seen on my profiles, even when an alignment starts at 0+00 and goes to something like 1+53 from a few structures, you have to set the profile view to something like -0+50 and 2+00 (or some other value beyond the length of the profile) for those end structure and pipe labels to show up.
    But, if it's a band thing, you'll want to check the option to show band labels at start and end...
    Valued Contributor
    03-08-2012 06:53 AM in reply to: keith.kempker
    here is what i usually do.
    1. check to make sure the pipe or structure is tied to an alignment and right on top of the alignment and not offset
    2. ensure the pipe or structure is tied to a surface
    3. run a  -PURGE then R for regapps
    4. then audit
    5. then REA for regenall.
    6. also check to ensure that you are still pointing to the correct pipes catalog
    7. if you still can't label the pipe i will do a pipe swap then swap it back to what it was originally.
    Tony
    CAD Manager
    www.tonyscivil3dworld.blogspot.com
    Active Member
    keith.kempker
    03-09-2012 06:56 AM in reply to: keith.kempker
    Still can't label the pipe.  Here is the kicker, I can label the pipe in plan just fine, just not in profile view.  Here is what I get:
    Select profile view:
    Selected entity must be of type: Profile View
    johnm
    03-09-2012 07:30 AM in reply to: keith.kempker
    Are you selecting the profile view before selecting the pipe?
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    Active Member
    keith.kempker
    03-09-2012 07:51 AM in reply to: johnm
    no
