• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    Joe-Bouza
    Can't get Pastel colors assigned to surface range
    271 Views, 9 Replies
    10-05-2012 05:15 AM
    I have a volume surface that I want cut & fill displayed with elevation banding. I created a surface style and chose pastels for the color scheme. When I analyze the surface I chose elevations>> range interval with datum and I get 2d solids but they are not pastel even though the style assigned is the one I mentioned.
    How do I get the colors to be pastel?
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Please use plain text.
    *Expert Elite*
    johnm
    Re: Can't get Pastel colors assigned to surface range
    10-05-2012 07:16 AM in reply to: Joe-Bouza
    Did you recompute the surface analysis, i.e. add the ranges again?
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    *Expert Elite*
    johnm
    10-05-2012 07:19 AM in reply to: Joe-Bouza
    Can you post or send a file? I just did this and it worked fine in 2012.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    *Expert Elite*
    Joe-Bouza
    10-05-2012 07:51 AM in reply to: johnm
    Thanks John. Its on the way
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    Valued Mentor
    10-05-2012 08:20 AM in reply to: Joe-Bouza
    What color scheme are you getting instead of the pastels? That might be the key to finding which style or setting is off.
    *Expert Elite*
    johnm
    10-05-2012 08:32 AM in reply to: Joe-Bouza
    The elevation banding needs to be recomputed after seeing Joe's file.
    In the Surface Properties dialog, Analysis tab, select Elevation Ranges, assign the number of desired ranges and then hit the chevron arrow to recompute/repopulate the computed slope ranges listed.
    This is similar to the issue many of us had with label styles when we were learning C3D. We never hit the Arrow button to update the data.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    *Expert Elite*
    Joe-Bouza
    10-05-2012 08:46 AM in reply to: johnm
    pastels.PNGOk. I’m a bigger dope than I thought. I’ve repopulated that button at least a dozen times and never get pastels? I can’t find the chevron because I only have a down arrow.
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    *Expert Elite*
    Joe-Bouza
    10-05-2012 08:46 AM in reply to: KirkNoonan
    Thanks Kirk,
    I posted images to JM
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    *Expert Elite*
    johnm
    10-05-2012 11:20 AM in reply to: Joe-Bouza
    With Kirk's recommendation and Joe's sleuthing we can see that users do not have the ability to edit the fields that need to be edited.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    *Expert Elite*
    Joe-Bouza
    10-05-2012 12:37 PM in reply to: johnm
    I'll open an SR on Monday.
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
