• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    lohrmach
    Can't edit elevations of Feature Line
    530 Views, 6 Replies
    04-19-2012 08:21 AM
    I Created a Feature Line from Objects (a polyline).  I added it to Site 1, gave it a name, layer.  Do I Assign elevations during creation (conversion options)?
    I set the Elevation to 8.5  (NOT From surface)
    Then I go to
    Modify Feature Line -
    Elevation Editor.
    Why are the elevations locked?  I want to set them.
    Lohrmach
    Please use plain text.
    Valued Mentor
    owenmull
    Re: Can't edit elevations of Feature Line
    04-19-2012 08:39 AM in reply to: lohrmach
    Then I go to
    Elevation Editor.
    When you go to Modify tab and select Feature Lines-->Edit Elevations->Elevation Editor, it should prompt you to select the Feature Line.
    Another way to do it is to click on the Feature Line itself and the ribbon toolbar will appear for that Feature Line and you can access the Elevation Editor there, too.
    -Owen
    Windows 7 x 64 bit
    ATI FirePro V4800 Triple Monitor
    12 GB RAM
    Intel Xeon W3550 @ 3.07 GHz
    Civil 3D 2012 SP 2
    ______________________________________________________________
    Intel inside. Idiot outside.
    Usually, I find that the problem is between the keyboard and the chair.
    TRogers
    04-19-2012 08:48 AM in reply to: lohrmach
    If the elevations were assigned from a surface, then you can't edit them.  It's reading from the surface.  If you assigned elevations manually, or added intermediate grade break elevations from within the elevation editor, then you can change them.
    If the issue was resolved by this method, please click on "Accept As Solution"
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    Valued Contributor
    lohrmach
    04-19-2012 09:08 AM in reply to: lohrmach
    I created a new Site - seemed to solve.  I must have added the feature line to a Site that cause the feature line elevations to lock into the surface associated with that Site or something, maybe a corridor surface.
    Lohrmach
    Valued Mentor
    04-19-2012 09:29 AM in reply to: TRogers
    If the elevations were assigned from a surface, you can most definitely edit them. The original assignment gives them their starting elevations, but no dynamic connection is established and they can be edited at will after assigment from a surface.
    Employee
    04-19-2012 11:49 AM in reply to: lohrmach
    Feature lines don't lock on to surfaces for their elevation. The "elevations from surface" is a once and done grab.
    Feature lines will take elevations from other types of Site Geometry on the same site. Some exaples are: parcel segments, other feature lines, grading objects, etc.
    Dana Probert, P.E.
    Technical Marketing Manager, Civil Engineering
    Blog: BIM on the Rocks
    Learn More About BIM for Infrastructure
    Valued Mentor
    owenmull
    04-19-2012 11:59 AM in reply to: dana.probert
    Feature Lines of the same Site will interact with each other, ie if feature lines of diferent elevations overlap, in 3D view they will intersect. If they are in seperate Sites, they will not.
    -Owen
    Windows 7 x 64 bit
    12 GB RAM
    Civil 3D 2012 SP 2
