AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Can't browse to open file
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
When I open the software and try select "open", I have to type in the name of the drawing and path on the command line, it won't allow me to browse for the drawing or show recently used drawings. I can work around this by typing in the path and name, but it is inconvenient. Is there a setting that I need to change?
Re: Can't browse to open file
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
FILEDIA=1 I think (IIRC)?
Reid
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That worked! Thank you!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
My computer just started doig that.
Where do I type "FILEDIA=1" ?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Do you not have a command line? It may be you have turned it off but you should still be able to type commands. Press escape several times to cancel any active commands and then type FILEDIA and hit enter. Normally you would then see a prompt on the command line for inputting a value. If you can't see the command line just type the number one after hitting enter and you should then start getting the dialogues when opening files.
If you press Ctrl+9 it should restore your command line.
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Neilw wrote:Do you not have a command line?
Since Autocad needs a path to open/save files, that means the command line is visible somewhere...
I concur with CTRL-9 or, even quicker, by pressing F2 to trigger the biggest text window.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks. That worked.
