• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    CountyUser
    Can't browse to open file
    691 Views, 6 Replies
    07-12-2011 08:35 AM
    When I open the software and try select "open", I have to type in the name of the drawing and path on the command line, it won't allow me to browse for the drawing or show recently used drawings.  I can work around this by typing in the path and name, but it is inconvenient.  Is there a setting that I need to change?
    Please use plain text.
    Valued Mentor
    Re: Can't browse to open file
    07-12-2011 09:12 AM in reply to: CountyUser
    FILEDIA=1  I think (IIRC)?
    Reid
    Homebuilt box: I5-2500k, MSI P67A-GD65, 12gig DDR3 1600 ram, ASUS ENGTX460 Video card, WD Velociraptor WD4500HLHX HD, Win 7 64 pro.
    Member
    CountyUser
    07-12-2011 09:17 AM in reply to: OMCUSNR
    That worked!  Thank you!
    New Member
    02-02-2013 10:09 AM in reply to: CountyUser
    My computer just started doig that.
    Where do I type  "FILEDIA=1" ?
    Neilw
    02-02-2013 11:35 AM in reply to: falcon125
    Do you not have a command line? It may be you have turned it off but you should still be able to type commands. Press escape several times to cancel any active commands and then type FILEDIA and hit enter. Normally you would then see a prompt on the command line for inputting a value. If you can't see the command line just type the number one after hitting enter and you should then start getting the dialogues when opening files.
    If you press Ctrl+9 it should restore your command line.
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    antoniovinci
    02-02-2013 01:17 PM in reply to: Neilw
    Since Autocad needs a path to open/save files, that means the command line is visible somewhere...
    I concur with CTRL-9 or, even quicker, by pressing F2 to trigger the biggest text window.
    New Member
    02-04-2013 08:48 AM in reply to: CountyUser
    Thanks. That worked.
