• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Can't Edit COGO Points
    268 Views, 8 Replies
    12-04-2012 12:14 PM
    Hi guys, Civil3D 2013 user here,
    I was working on my topo today for a few hours when all of a sudden I can no longer snap to a node of the COGO points. By node  I mean the tiny box that appears when you click on a COGO point that lets you rotate the point, move it, move the leader vertex, etc. I can still snap to the nodes of any other object in the drawing, just not the COGO points.
    Also, I can no longer select any existing objects on a few layers. These objects were extracted from a surface and manipulated and are now just polylines. I can draw new objects on those layers and select them just fine but the current ones I can't select at all.
    I just went to open the drawing on someone else's computer and I'm having the same problem. In fact, the objects on the layers I extracted from the surface don't even show up on the other computer.
    I installed the new SP before I left last night, so I assume that might be a problem, but like I said it was working fine for the first five hours of the day and the other computer I used had not yet installed the SP. What the heck is going on?
    EDIT: I should add that I'm only having problems with this one drawing. All my old drawings still work like they should.
    Please use plain text.
    Re: Can't Edit COGO Points
    12-04-2012 01:17 PM in reply to: dankoss
    After playing around during lunch I have a few other details.
    If I use the move command and type in ALL the objects that I cannot select still move along with the rest of the drawing.
    If I copy and a paste a COGO point (Ctrl V/Ctrl C) to a new drawing I can select the COGO point atttribute nodes. When I W block out the COGO point into a new drawing I still cannot select the nodes.
    12-05-2012 08:54 AM in reply to: dankoss
    Have you tried Audit or Recover?
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    12-05-2012 09:04 AM in reply to: troma
    I just tried those and no effect. My workaround right now is doing a SELECT, ALL (only way I can select the objects on the funky layer) and then doing a Ctrl C/Ctrl V into another drawing. The new drawing works fine but the old one is still broken. The old one did work briefly after I did the steps above, but then the program crashed, as it likes to do, when I tried to exit or maybe I was saving or maybe just trying to print, and then the old drawing had the same problems again.
    12-05-2012 09:47 AM in reply to: dankoss
    I dunno.  You should also check if any layers are locked, or if the points are locked, but to be honest it sounds like something more serioius.
    12-05-2012 10:41 AM in reply to: dankoss
    Can you post, or otherwise share, the problem drawing?
    12-05-2012 10:47 AM in reply to: Jeff_M
    Here's the drawing. The two funky layers are the contours. C-CONT-MJR and C-CONT-MIN.
    Judging by how these things usually work I fully expect you to come back and say "Well it worked on my computer."
    12-05-2012 11:41 AM in reply to: dankoss
    OK, don't ask me why because I don't have any idea, but....
    Open the drawing, in layer manager save a layer state, thaw all layers, regen. The objects will now be selectable/editable. Restore the layerstate, the objects are still editable. Save and close the drawing. Reopen the drawing, once again cannot select/edit those objects. Thaw all layers, regen. You can now select/edit, save, close, open...you will still be able to select/edit the objects.
    This tells me there is something odd with one of the layers which is being frozen. I don't have time to investigate what that may be, or which one(s) are causing it.
    Hope that helps a bit.
    12-05-2012 12:11 PM in reply to: Jeff_M
    Thanks for the help. At the least that's a much quicker and eaiser work around than what I did.
