• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    Joe-Bouza
    Accepted Solution
    Can PDF size be reduced
    231 Views, 10 Replies
    01-17-2013 05:40 AM
    Is there a setting that can reduce the sized of a PDF plot? I currently use DWGtoPDF.pc3 and I plotted a 13 sheet set that came out at 35MB. If I plot them as individuals some are 500K and some are 6MB; probably due to images.
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Please use plain text.
    *Expert Elite*
    AllenJessup
    Re: Can PDF size be reduced
    01-17-2013 06:11 AM in reply to: Joe-Bouza
    Joe,
    Not that I'm aware of in AutoCAD Civil 3D. Adobe Standard will do it. I use an inexpensive program, CutePDF Pro, to do it. You can download a trial version. There will be degradation to the images. You'd actually have to try it to see if it would be acceptable.
    Another thing that might help is if you reduced the image size outside of AutoCAD and repathed the attached images to the smaller versions.
    *Expert Elite*
    Joe-Bouza
    01-17-2013 06:12 AM in reply to: AllenJessup
    Thanks Allen. I thought that to be the case. I have tried those options you suggest.
    Thank you
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    *Expert Elite*
    AllenJessup
    01-17-2013 06:30 AM in reply to: Joe-Bouza
    Have you tried printing with an external PDF printer like CutePDF (the free version)?
    *Expert Elite*
    Joe-Bouza
    01-17-2013 06:32 AM in reply to: AllenJessup
    That I have not. I'll try the download. The problem I have there is I would need every workstation to get it, no? Which means I would have to go around installing
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    *Expert Elite*
    AllenJessup
    01-17-2013 06:59 AM in reply to: Joe-Bouza
    Yeah. I just throw the install file on the network and visit each workstation.
    Valued Mentor
    TerryDotson
    01-17-2013 07:25 AM in reply to: Joe-Bouza
    Post or email me one and I'll let you know what's inside.
    *Expert Elite*
    01-17-2013 07:40 AM in reply to: Joe-Bouza
    Have you tried to reduce the resolution in the plotter settings before printing? I have one setup for 150 DPI when dealing with aerials. It's usually about half the size and very little loss in clarity.
    Bruce Klug
    AutoCAD Expert Elite
    AutoCAD Civil 3D 2013 Certified Professional
    C3D 2013 (SP1)
    C3D 2014 (Testing)
    Win 7 Pro, 64-bit
    *Expert Elite*
    Joe-Bouza
    01-17-2013 07:44 AM in reply to: klugb
    Thats the button I could not find! Thanks I'll report back
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    *Expert Elite*
    Joe-Bouza
    01-17-2013 08:10 AM in reply to: klugb
    Chopped of 10 megs
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
