• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Civil 3D
    *Burgasser, Drew
    Re:
    11-17-2003 09:32 AM in reply to: *Rogerson, Michael
    Hi Fred:
    Out of curiousity, how do you show and label a left or right FL vertical
    curve around a horizontal curve on the CL profile? Would it not be
    distorted in relation to the CL? Do you show the distorted view and just
    label grades of small segments of the vertical curve?
    Drew Burgasser
    CAD Masters, Inc.
    "Fred Ernst" wrote in message
    news:C2A610F5BD288ACDA6584C3008C5593E@in.WebX.maYIadrTaRb...
    Hi Michael:
    We actually need the ability to design the transitions (gutter flowline
    usually) as "independent" alignments and profiles, but they need to have an
    intelligent cross slope relationship with CL. We need a flag or a display
    where we can see the cross slope left and right of crown at each CL station.
    Now, people are designing all three profiles, and "hand checking" the crown
    cross slopes, which is very tedious and eats profit margins.
    Fred
    "Michael Rogerson" wrote in message
    news:4912A6E0F243A93A15AD41F7EB7A6326@in.WebX.maYIadrTaRb...
    Howdy Gene,
    Thanks, understand - a common need seems to be the ability to first plot,
    then annotate parallel and non-parallel offsets on the CL profile (or onto
    any profile for that matter).
    The annotation of the non-parallel entities as superimposed on the CL
    profile needs a few things:
    1) Label true grades along the offset (not the grades as the appear in the
    CL profile)
    2) The abiliy to label stations along the offset (not the CL stations) on
    the CL profile. These stations distances would be non-linear in the case
    where an offset was non-parallel, curved or bent.
    From you comments, I'm assuming that for design development, you would
    likely work with profiles for the offsets as well as the centerline. But,
    for review and construction drawings, these would often all be represented
    on the CL profile?
    let me know if I'm not clear here, or off-base. Thanks.
    Mike
    "gredmon" wrote in message
    news:f19b375.15@WebX.maYIadrTaRb...
    Mike,
    Our situation is similar to Fred's further down in this thread. We are
    required to show all 3 profiles. Left curb, CL and Right curb. They all must
    be fully annotated with actual lengths shown where curbs are not parallel
    with CL.
    Our CL profile actually always continues to the top of curb in the middle of
    the the large radius (back of cul-de-sac) where all the profiles end at an
    identical point.
    This method provides us the opportunity to control all the warping in the
    cul-de-sac with individual profiles and provide curb staking onsite.
    Hope this helps.
    Gene
    Please use plain text.
    *Rogerson, Michael
    Re:
    11-18-2003 03:01 AM in reply to: *Rogerson, Michael
    Gene, Fred, Drew - Good stuff.
    As Drew pointed out, the offsets will most
    often be "skewed" when represented on the centerline profile, as the true
    length along the offsets is not the same as the lengths represented on the CL
    profile.
    So, I can say this - that things like vertical
    curves may need to be represented as a series of chord segements (the
    resolution of which should be user-controlled).  Labeling offsets should be
    able to reference cardinal points (like grade breaks on the offset, as well as
    offset VC start/end HP/LP, etc.)
    Fred - the notion of labelling the true grade from
    CL to offset is quite understood, especially when you mention profit
    margins! - only one assumption to clarify - you would want the grade
    measured perpedicular from the CL out to the offset?  Of course, if all of
    this were creating a surface, the normal to the surface from a point on the CL
    might be of more interest.
    Gene - the question that comes to mind from your
    repsonse is if you expect to be able to edit the "skewed"
    representation of the offset profile when it's shown on the CL profile.
    This leads to all sorts of other things like how you would exepect it to behave,
    etc.  Hence my question - I was assuming that you were working on the
    Offset profiles independantly, while only showing the representation of them on
    the CL profile (not editing then there).  Thoughts?
    thanks again!
    Mike
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    I
    know this is no easy task, but its what we have to do.
    As far as the 3 lines of the profile. You mention design development and
    construction drawings. Right now there is no difference. We use a custom app
    built on LDT to design all 3 lines of the profile simultaniously (each line
    gets its own horiz. alignment) then produce a single profile that shows all 3
    lines separated vertically by a 100 grid. This profile gets externally
    referenced into our construction drawings for plots that are used for plan
    check and construction staking.
    If I understand what your suggesting is that 3 different profiles could be
    used to develop the design and then brought together as a representation on a
    single (CL) profile for construction drawings should work. In theory...
    Let me know if I miss understood.
    Gene
    *Ernst, Fred
    Re:
    11-18-2003 05:55 AM in reply to: *Rogerson, Michael
    We have to show three separate profiles now on one plan\profile sheet.
    Fred
    "Drew Burgasser" wrote in message
    news:AA6C5F73EAED9C82C871AA60A64895E9@in.WebX.maYIadrTaRb...
    > Hi Fred:
    > Drew Burgasser
    > CAD Masters, Inc.
    > Hi Michael:
    an
    station.
    crown
    > Fred
    message
    > Howdy Gene,
    > CL profile)
    > on the CL profile?
    > Mike
    > Mike,
    must
    > with CL.
    of
    > identical point.
    > Hope this helps.
    > Gene
    *Ernst, Fred
    Re:
    11-18-2003 06:07 AM in reply to: *Rogerson, Michael
    The normal sounds good as you mention it.
    All this being said, trying to design a
    road from conception using three profiles is pure insanity. The more
    sane approach is to use traditional CL template design techniques for the
    initial design, and then go back and tweak the flowlines to fix flat
    stretches, get inlets situated, etc. Then be able to show the
    flowline cardinal (like that word) information on one CL
    profile.
    Fred
    profile.
    be able to reference cardinal points (like grade breaks on the offset, as well
    as offset VC start/end HP/LP, etc.)
    from CL to offset is quite understood, especially when you mention profit
    of this were creating a surface, the normal to the surface from a point on the
    CL might be of more interest.
    behave, etc.  Hence my question - I was assuming that you were working on
    the Offset profiles independantly, while only showing the representation of
    them on the CL profile (not editing then there).  Thoughts?
    thanks again!
    Mike
    I
    3 lines separated vertically by a 100 grid. This profile gets externally
    be used to develop the design and then brought together as a representation
    on a single (CL) profile for construction drawings should work. In theory...
    Gene
    *Rogerson, Michael
    Re: Call for Cul-de-sac Examples
    11-20-2003 12:42 AM in reply to: *Rogerson, Michael
    Hi, whoever you are:
    This is definitely all tied to one and the same. I'm latching on to this
    subject for the moment as it represents a part of road design that typically
    falls away from a normal typical section design process, as do
    intersections. While we may be able to provide a "push-button" soulution to
    a simple road design, cul-de-sac design is usually so case/site specific, it
    is more likely that we provide automation tools to make the more common and
    time consuming parts easier, as well as some "push-button" items.
    From the great responses we've gotten from this thread, it's clear that
    there are common tool needed for both cul-de-sacs and roads, take the
    representation and labelling of offset profiles for example. It's clear we
    need it for both.
    Hard to tell - was that an answer?
    Mike
    wrote in message
    news:smileyvery-happy:1F4421C89C17CCDE2A680804E9FB7B3@in.WebX.maYIadrTaRb...
    > Michael, how about some solutions for design of cul-de-sacs as part of
    road
    > design, not just as horizontal layout? Intersections?
    message
    > news:EB99763198557D9680B6C63BBBCDE3E6@in.WebX.maYIadrTaRb...
    > > In Civil 3D, we would like to expand our solution base for Cul-De-Sac
    > > creation, as well as improve useability. We hope to get are some
    > particular
    > > common (and not-so-common) configurations for Cul-de-sacs, in regards to
    > the
    > > horizontal alignment, offsets and, additionally, 3D design details to
    help
    > > automate the process.
    > > Preferred examples would be contained in DWF or DWG files. Also, any
    > > available agency standards and examples would be useful as well. We
    seek
    > > this input to continue improving Autodesk Civil 3D.
    > > If you can help, please respond/send examples directly to me at the
    > > following email address:
    > > mike.rogerson - Add "autodesk.com" at the end of that. If you reply
    > > directly to me from this post, make sure to remove the SPAM protection
    > from
    > > my reply address.
    > > Thanks for any help!
    > > Mike
    > > Autodesk, Inc.
    > > Michael C. Rogerson, PE
    > > Product Designer - Program Manager
    > > ISD Civil Engineering Software Development
    *Townes, Tyler
    Re:
    11-25-2003 03:15 AM in reply to: *Rogerson, Michael
    Hi Michael,
    Like others, we have designed many cul-de-sacs and I think each has been
    unique. We have been leaning mostly towards straight grading the flowline
    along the curve to guarantee drainage, which causes ACC warping. Where
    grades are steep enough we can plane grade the ACC, but have to be careful
    near the inlets for shallow grades. From a drafting standpoint we use spot
    elevations and %grade arrows on the plan and CL grade on the profile. But,
    like others are regulated to, we too may someday need to show true flowline
    grades on the profile.
    Thanks for listening,
    Tyler Townes
    news:E28A2ACC8D019D4991ACCF9F179AB285@in.WebX.maYIadrTaRb...
    typically
    to
    it
    and
    we
    > need it for both.
    > Mike
    > wrote in message
    > road
    > message
    > > particular
    to
    > > the
    > help
    > seek
    > > from
    > > > my reply address.
    > > > Mike
    > > > Autodesk, Inc.
