• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Re: Calc Area in Acres
    03-01-2012 07:13 AM in reply to: dsigman
    Thanks for the Line Label tip DSIGMAN!!!!
    I've been looking for something like this. Being able to display the area dynamically without having to convert to a Parcel is great. My polyligns were overlapping and like an earlier post stated the overlapping Parcels don't play well. Tried the field method but it's to cumbersome to add new labels to other objects.
    Civil 3D 2012
    Windows 7 Pro (64bit)
    Intel Xeon W5580 @3.20GHz
    12gig RAM
    NVIDIA Quadro 600
    Please use plain text.
    dsigman
    03-01-2012 12:20 PM in reply to: mjung
    You're welcome.
    Valued Contributor
    04-17-2012 05:48 AM in reply to: dsigman
    This could be just what I'm looking for. But, is there a way to keep it from labeling every single line segment in the bpoly? Also, I can not keep the label from including the tag number.
    Randy A. Owens
    Southland Engineering, Inc.
    Win 7 64BIT
    C3D 2013
    dsigman
    04-17-2012 07:27 AM in reply to: randyowens3203
    I just label a closed polyline on any one of the segments and the label returns the area. I've configured it for square feet and acres. I used the General Overall Area variable to create it.
    I'm not sure what you're getting at with the tag number. In the Label Style Composer, in the Tabel Tag group, I suspect you may have the "Used In" setting set to "Label and Tag Modes"  instead of just "tag mode":
    I'll try to attach screen shots of the settings I used.
    Valued Contributor
    04-17-2012 07:39 AM in reply to: dsigman
    I've got it now. Thanks.
    Randy A. Owens
    Win 7 64BIT
    C3D 2013
    Employee
    04-17-2012 09:34 AM in reply to: castled071049
    Here is an old (but still good) post using line labels for elevations. At the end, I have an example using a line area label for silt fence.
    http://civil3drocks.blogspot.com/2006/06/label-style-for-calling-out-elevation.html
    Dana Probert, P.E.
    Technical Marketing Manager, Civil Engineering
    Blog: BIM on the Rocks
    Learn More About BIM for Infrastructure
    04-17-2012 03:34 PM in reply to: castled071049
    I've been getting frustrated in C3D 2011/2012 by the fact that some Parcel curve labels have incorrect deltas...  Seems to happen most when using large coordinate values, such as ones related to State Plane.  I think it's created by a precision error, which causes C3D Parcels to include erroneous extra very tine curve segments (with 0.000 length, but a delta angle) that gets "added" to the value shown in the label.  Very disturbing, since it can cause plats to show incorrect delta angles in curves, and the problem is very hard to catch.
    Just really confused by how I never had this problem in C3D 2010 and earlier...
    Sinc
