AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
COPY/PASTE problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello!
In this video is shown what "strange" objects appear after copy/paste via clipboard.
1. Opened "talv.dwg", INSERT block "rihtimine 3tee" with "explode" option enabled.
2. Trying to copy some objects via clipboard into the same file.
- first try - no sucsess;
- second try - some set of lines appeared, like "grass' hatch.
- third try - another unwanted shape - set of lines like two rectangles one above another.
Only these two unwanted shapes appear with this copy/paste via clipboard issue.
Somtimes no problem (like in video - opened new file, and pasting here - was sucsess), sometimes nothing been copied, sometimes those strange shapes.
Also we have a problems with inserting of BLOCKS with this issue.
talv.dwg link:
https://skydrive.live.com/redir?resid=D99EA11F0AA7
PS. This first videofile a littile bit large - about 1.8Mb, so I uploaded to youtube :
http://www.youtube.com/watch?v=OPGO4c9b_fo&feature
Second similar attempt is attached to this post.
Can anybody help us?
Re: COPY/PASTE problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Not much time to watch videos right now, sorry. But one question: are you pasting objects from a newer version of C3D back to an older version?
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you for reply,
Versions are the same.
Earlier I asked this question on AutoCAD 2013 forum - here is more detail about this issue:
http://forums.autodesk.com/t5/AutoCAD-2013/2013-Co
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Intenta con esto, es un aplicativo (lisp).
Eddy
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I tried to replicate your issue on one of the tutorial drawings and with your talv.dwg and each time copy/paste worked fine. I used right-click copy/paste as well as CTRL+C/CTRL+V and COPY command withing AutoCAD with no difference. See video: http://screencast.com/t/3nTXbzVqbY
It seems that you may be having some issues with your installation. I'd suggest running repair and trying it with any of these draiwngs: C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\Help\Civil Tutorials\Drawings
Good luck!
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I typically find that a lot of times it's only the profile that's corrupt. For this reason I create a copy of the default Civil 3D profile for everyday use then if there's an issue such as this one I have the user try to duplicate the issue in the default C3D profile. If the issue doesn't happen in the default C3D profile then the username profile gets renamed to "bad" and I rebuild the new username profile from the default C3D profile again.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I should have taken troma's advice. I watched your video for about 3.5 of the 6 minutes and cannot discern what you are trying to show.
But I have to ask the question: Why wouldn't you simply use the copy command to copy this object? I use the clip board but not a big fan of its use.
I have people that use it to create blocks on the fly and end up with drawings full of blocks with names like AC$44F556R67UPL8Y972.
Lots of fun when you want to count something
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello!
Q: "Why wouldn't you simply use the copy command to copy this object?"
A: I need to copy objects from one file to another.
This issue is investigated, and lot of thanks to Kean Walmsley.
The bug was in the file - huge amount of unreferenced strokes, that we cannot purge with usual "-purge".
After running this awesome DGNPURGE utility - filesize is more than 50% less, and Copy/Paste - works!
Regards.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi rutar,
Please can you share thsi tool? I have the same problem, but I'm a complete disaster on programing.... I'm just an architect
Peter
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Do you have a compiled dll file for DGNPURGE I am having compile problems with the code.
I have a very lareg project where users cannot copy paste bcuse of the DGN data.
Thankyou in annticipation
Stella
