• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    rutar
    Accepted Solution
    COPY/PASTE problem
    848 Views, 11 Replies
    11-26-2012 06:30 AM
    Hello!
    In this video is shown what "strange" objects appear after copy/paste via clipboard.
    1. Opened "talv.dwg",  INSERT block "rihtimine 3tee" with "explode" option enabled.
    2. Trying to copy some objects via clipboard into the same file.
     - first try - no sucsess;
    - second try -   some set of lines appeared, like "grass' hatch.
    - third try - another unwanted shape - set of lines like two rectangles one above another.
    Only these two unwanted shapes appear with this copy/paste via clipboard issue.
    Somtimes no problem (like in video - opened new file, and pasting here - was sucsess), sometimes nothing been copied, sometimes those strange shapes.
    Also we have a problems with inserting of BLOCKS with this issue.
    talv.dwg link:
    https://skydrive.live.com/redir?resid=D99EA11F0AA70C9A!9151&authkey=!AOFR-289ashaCDM
    PS. This first videofile a littile bit large - about 1.8Mb, so I uploaded to youtube :
    http://www.youtube.com/watch?v=OPGO4c9b_fo&feature=youtu.be
    Second similar attempt is attached to this post.
    Can anybody help us?
    Please use plain text.
    *Expert Elite*
    Re: COPY/PASTE problem
    11-26-2012 07:02 AM in reply to: rutar
    Not much time to watch videos right now, sorry.  But one question: are you pasting objects from a newer version of C3D back to an older version?
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Active Contributor
    rutar
    11-26-2012 07:14 AM in reply to: troma
    Thank you for reply,
    Versions are the same.
    Earlier I asked this question on AutoCAD 2013 forum - here is more detail about this issue:
    http://forums.autodesk.com/t5/AutoCAD-2013/2013-Copy-Paste-problem/td-p/3666864
    New Member
    11-26-2012 12:27 PM in reply to: rutar
    Intenta con esto, es un aplicativo (lisp).
    Eddy
    Product Support
    AlmasSuljevic
    11-28-2012 07:45 AM in reply to: rutar
    I tried to replicate your issue on one of the tutorial drawings and with your talv.dwg and each time copy/paste worked fine. I used right-click copy/paste as well as CTRL+C/CTRL+V and COPY command withing AutoCAD with no difference.  See video: http://screencast.com/t/3nTXbzVqbY
    It seems that you may be having some issues with your installation. I'd suggest running repair and trying it with any of these draiwngs: C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\Help\Civil Tutorials\Drawings
    Good luck!
    Almas Suljevic
    Product Support Specialist
    Autodesk Global Subscription and Support
    Autodesk, Inc.
    Please click on "Accept as Solution" if post helped you resolve the issue.
    Valued Contributor
    C3D_TomR
    11-30-2012 03:29 PM in reply to: AlmasSuljevic
    I typically find that a lot of times it's only the profile that's corrupt. For this reason I create a copy of the default Civil 3D profile for everyday use then if there's an issue such as this one I have the user try to duplicate the issue in the default C3D profile. If the issue doesn't happen in the default C3D profile then the username profile gets renamed to "bad" and I rebuild the new username profile from the default C3D profile again.
    *Expert Elite*
    Joe-Bouza
    11-30-2012 03:39 PM in reply to: rutar
    I should have taken troma's advice. I watched your video for about 3.5 of the 6 minutes and cannot discern what you are trying to show.
    But I have to ask the question: Why wouldn't you simply use the copy command to copy this object? I use the clip board but not a big fan of its use.
    I have people that use it to create blocks on the fly and end up with drawings full of blocks with names like AC$44F556R67UPL8Y972.
    Lots of fun when you want to count something
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Active Contributor
    rutar
    01-25-2013 04:02 AM in reply to: Joe-Bouza
    Hello!
    Q: "Why wouldn't you simply use the copy command to copy this object?"
    A: I need to copy objects from one file to another.
    This issue is investigated, and lot of thanks to Kean Walmsley.
    The bug was in the file - huge amount of unreferenced strokes, that we cannot purge with usual "-purge".
    After running this awesome DGNPURGE utility - filesize is more than 50% less, and Copy/Paste - works!
    Regards.
    New Member
    03-05-2013 05:09 AM in reply to: rutar
    Hi rutar,
    Please can you share thsi tool?  I have the same problem, but I'm a complete disaster on programing.... I'm just an architect :smileywink:.
    Peter
    New Member
    sarch
    04-10-2013 01:53 AM in reply to: rutar
    Do  you have a compiled dll file for DGNPURGE I am having compile problems with the code.
    I have a very lareg project where users cannot copy paste bcuse of the DGN data.
    Thankyou in annticipation
    Stella
