AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
COGO points duplicatin g along crown of corridor
- Highlight
- Email to a Friend
Hi guys
I have created COGO points from my corridor, there seems to be 2 sets of points ontop of each other along the crown of the road. They are different numbers, so its not the same point twice, anyone know why it would do this?
Martin
Re: COGO points duplicatin g along crown of corridor
- Highlight
- Email to a Friend
I don't know. Are they at the same elevation?
Allen
- Highlight
- Email to a Friend
You're probably generating points for multiple codes at centerline, such as pave1, pave 2, subgrade, etc... You can create points from the horizontal and vertical alignments that define the corridor using "Create Points- Alignment- Divide/Measure Alignment" if all you need is finish grade at centerline.
- Highlight
- Email to a Friend
The lane subassemblies have an option to turn the crown point codes on or off. If you have this option turned on for both sides of the road then you'll get duplicate featurelines and probably duplicate points created along the crown. Check your assembly and try turning off the crown option for one side.
- Highlight
- Email to a Friend
Thanks SBoon, thats what the problem was, it was taking both subassemblies points
thanks so much for this.
