• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    COGO Points won't display in one of my layouts
    516 Views, 3 Replies
    04-12-2012 02:11 PM
    I've been looking all over for a solution and can't find one. So, here's my problem:
    I have a layout in my drawing (Civil 3d 2011) with multiple viewports and my point symbols (trees, manholes, etc.) won't display. I have other layouts in the same drawing that display them fine, but I need to use this specific layout for what I'm doing. This must be a setting of some sort but I can't seem to figure it out. Any ideas?
    Matthew
    Please use plain text.
    Product Support
    borycep
    Re: COGO Points won't display in one of my layouts
    04-13-2012 03:12 PM in reply to: aacdebo
    Hi Matthew,
    Are your point symbols on a drawing layer that is frozen for a particular viewport?
    You should be aware that it's possible to freeze and thaw layers, not just drawing-wide, but viewport-by-viewport. See the attached screenshot for the settings to look for.
    Does this resolve your issue?
    Phil Borycens
    Support Specialist
    AEC Infrastructure
    New Member
    04-13-2012 03:23 PM in reply to: borycep
    Thanks Phil,
    Right on target. I have a layout with 7 viewports and had to thaw them for each. Sheesh!
    On a similar note, some of my polylines that are the same type and on the same layer are displaying
    differently in those different viewports. I have enabled linetype generation for them, set PSLTSCALE to 1, and TILEMODE to 0, and the lnetype scale on the layer to one. I still have to adjust the scale through the viewport to get them to appear the same. All of my viewports are set at the same scale, too. Any Ideas?
    Thanks again,
    Matthew
    04-15-2012 07:54 PM in reply to: aacdebo
    TILEMODE should not have any effect for this.  All it does is switch you between paperspace and  modelspace.
    For most, the best way to work in 2008 and later is to have LTSCALE=1, PSLTSCALE=1, and MSLTSCALE=1.
    Sinc
