Hi folks – Please note that we’ve released Civil 3D 2014 Hotfix 1 on the data/download site that is intended for installation by all users.
The download site includes a detailed readme with information on changes that have been made. At a high-level…
Important note – the team worked hard to make the hotfix “un-installable”. Prior to installing, please review the readme as there are a few things to be aware of.
Dave Simeone
Dave,
How did the Confirmed Defect involving the Section Editor go unaddressed within this Hotfix/patch? We need this addressed ASAP.
It is very competitive out there and we need this Corridor Section Editior capability working correctly for our engineering work.
We want to use the XREF corridor targeting capabilites of Civil 3D 2014 immediately in our corridor design work in conjunction with the Section Editor, software that we have bought and paid in full for.
Fred
We're still researching this and other issues that have been reported. The scope for hotfix 1 was relatively small so that we could deliver critical fixes as quickly as possible with as much quality as possible. In some cases, we had to make hard decisions in order to meet the speed/quality criteria. We'll provide more information on status of solutions for the section view-edit issue and other important fixes as things solidfy.
Dave Simeone
Dave,
The corridor Section Editor is the main component of our corridor design process. As other engineers have stated, we essentially live there throughout the design process. We have to have it. It is unacceptable to have this main design component in a defective state.
This should be at the very top of your priority list.
Fred
Dave,
Fred is correct that this is a critical issue. We are waiting to switch everyone over to the 2014 Infrastructure Design Suite in our organization but this major issue is stopping deployment. I didn't bother creating a SR as it was a know issues and thought it would be one of the highest priorities.
I can't expect staff to design with this as our section view.
I experimented with this briefly but didn't look at it in detail. It appears to me that Civil3D objects are displayed properly in section view, but plain ACad objects are not being clipped correctly. Can someone confirm that this is the case?
The question I have is whether this issue was caused by a change within the Civil3d program code for the corridor view editor, or something has been changed in the core ACad software. If that is the case then we might be waiting a long time for this to get fixed.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
After installing this Hotfix 1 (and also Hotfix 1 for Map 3D 2014 here), I noticed that OSGeo providers are updated to 3.8 version which causes Map 3D 2013 and also Civil 3D 2013 to not being able to use the MAPIMPORT command anymore because they default to 3.7.
Autodesk can you confirm this?
A workaround is updating the providers.xml in the following directories:
C:\Program Files\Autodesk\Autodesk AutoCAD Map 3D 2013\bin\FDO
C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2013\bin\FDO
As described here for actually enabling the MAPIMPORT command in Map 3D and Civil 3D 2014, BEFORE the hotfixes were released.
Best,
John
@sboon wrote:I experimented with this briefly but didn't look at it in detail. It appears to me that Civil3D objects are displayed properly in section view, but plain ACad objects are not being clipped correctly. Can someone confirm that this is the case?
Steve,
I didn't have access to C3d when I initially read this thread but wanted to see if I could get the same results as Bruce posted. I tested a very simple corridor drawing without any Acad entities in it whatsoever and everything seemed normal. Then I attached 3 xrefs that are overlays comprised of AutoCad entities (Utility, Row and Geometric overlays) attached on layer zero (all at zero elevation) and a couple of random lines started to appear in Section Editor.
Then I drew a few 3d Polylines using node snap and snapped to some C3d Survey Points so the 3D Poly's would be in same elevation range as the sections and in the area of the corridor where I drew them, they appeared in Section Editor. These entities also appear in the other sections that are far away from test stations. The same was true for Mtext and a Circle. I also tried a C3d Feature Line and it didn't display in SE.
In my limited testing, I would agree with your observation that it may have something to do with AutoCad entities.
Bruce,
Can you confirm if the wild lines in your capture are all AutoCad entities?
Steve and Jay,
Yes, all of the green entities are from my survey drawing that is an xref (BTW, it doesn't matter if it's and xref or not) and "most" of the topo is 3D so it shows up here. The white lines are the leftover from the check sight distance routine which are a block of several 3D lines. I think the blue one was a polyline water line that went from 0 to a 3D elev at one end (my bad).
Looks like you have narrowed it down for sure.
Bruce,
Are the green entities strictly vanilla AutoCad primitives or are Survey Figures or Survey Points showing up in section editor? The reason I'm asking is I don't see any C3d objects such as Survey Figures or Survey Points here.
Jay,
No civil 3D entities in the survey base. It's a generic file from a Carlson import.
3D lines, 3d polylines 2D lines, 2D polylines, and points as blocks. Notes are dtext & mtext.
Hi Everyone - Thanks for the detailed feedback that you're all providing. The team is actively resarching the issue. As things progress we'll invite those who are interested into our on-line testing program that we've begun using. Short version is that you can test via a virtual machine hosted by us (aka, no need to download and install a build).
I"ll request names as we get closer to having something you can test.
Dave Simeone
"...I"ll request names as we get closer to having something you can test."
Geez thanks Dave for continiung to have your customers debug your software free of charge for you on their company time.
This is totally unacceptable. We have paid for software from you with the intention of putting it to immediate commercial use for our businesses. The egregious lack of QA procedures for software emanating from your group is getting worse with each release of Civil 3D, full releases and hot fix/sevice packs included.
We are in a similar situation here. We have 8 Designers unable to upgrade to 2014 until the Section Editor is fixed.
As stated in other posts, this is unacceptable and should be top of the priority list for Autodesk.
Thanks.
Ross.
This is so unfortunate...
We all continue to suffer financially, and in engineering capability, due to the software's continued poor leadership and management.
I have this problem "FDO Provider 'OSGeo.SHP' Not Registered" and can not figure out how to fix it. My company uses Civil 3D 2013. I was told internally that I could load 2014 and now I receive the error. I don't see a fix by Autodesk, can someone help? Bob, Thanks
Hi - There is background on the issue and a technical solution posted on the support site:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21699992&linkID=9240697
Cheers
Dave Simeone
Dave,
This thread is about the section editor issues but the link you posted is about the map import/export issues?
