• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    CIVIL 3D : Super elevations
    124 Views, 1 Replies
    12-13-2012 10:54 PM
    I did a user defined super for my road.  This worked well.  However when I deleted the super data.  To try something else.  The corridor shows 0% camber or crossfall.  How do I get the corridor to follw the default crossfall in the assembly again?
    Please use plain text.
    *Expert Elite*
    sboon
    Re: CIVIL 3D : Super elevations
    12-13-2012 11:59 PM in reply to: johanski
    This is a known issue, the superelvation regions don't delete correctly and without any numbers in the table it defaults the crossfall to zero.  The easiest solution in your case is to open the superelevation table and manually add your default values to the start and end of the alignment.
