• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Accepted Solution
    CIVIL 3D 2013 RUNNING ON WINDOWS 8
    1606 Views, 15 Replies
    01-23-2013 11:16 AM
    I recently upgraded my computer to run Windows 8 Pro.  Everything is working great except for the grading functions in Civil 3D.  All other areas function fine but when I am in a grading plan and try to do anything the program crashes and shuts down, any suggestions?
    Please use plain text.
    *Expert Elite*
    DarrenP
    Re: CIVIL 3D 2013 RUNNING ON WINDOWS 8
    01-23-2013 11:48 AM in reply to: lwalker
    Windows 8 is not a supported OS for Civil 3D which means autodesk did not test it on windows 8 so what ever problems you run into my or may not get fixed in 2013
    you can look through here for issues and workarounds other people have posted: http://forums.autodesk.com/t5/forums/searchpage/tab/message/?page=2&q=windows+8&search_type=thread
    Member
    01-23-2013 03:22 PM in reply to: lwalker
    So you are saying this problem with windows 8 and civil 3d crashing will not be fixed this year? Are they attempting to fix this?
    *Expert Elite*
    DarrenP
    01-23-2013 03:24 PM in reply to: john_gildersleeve
    maybe or maybe not
    windows 8 came out after civil 3d 2013 was released
    may have to wait until 2014 to release for a fix
    Member
    01-23-2013 03:29 PM in reply to: john_gildersleeve
    So how do you go about trying to get these problems fixed? Is autodesk attempting to try to help out? If so how do I get in touch with support?
    *Expert Elite*
    01-23-2013 03:39 PM in reply to: john_gildersleeve
    I don't, since I know that C3D2013, and earlier, is not officially supported by Autodesk. Nor do I expect them to. When the next version is released, assuming it will be Win8 compliant, then I may get a new PC with Win8. In the meantime, I will continue to work without too many progam errors with my trusty Win7 and C3D 2012/2013.
    If you want to submit a support request, there is a mechanism for that in the Subscription site. Not on Subscription? Then there's the web form: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
    Jeff_M, also a frequent Swamper
    *Expert Elite*
    01-23-2013 05:03 PM in reply to: john_gildersleeve
    You won't necessarily get this issue fixed, at least not by Autodesk. There might or might not be a service pack for 2013 to address this issue.
    I have had a couple clients who installed using Windows 7 Compatibility Mode and are up and running with no errors.
    Also, you if you want to spend some time with it, you can test in diagnostic startup. If that works, try selective startup and one-by-one re-apply the services you turned off. Eventually you'll find one that's conflicting with grading. This could take hours.
    Personally, I am doing what JeffM is doing. I'll install Win8 when Autodesk says they support it. At this point they have not said that.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Member
    01-23-2013 05:27 PM in reply to: john_gildersleeve
    Not sure how you install using windows 7 compatibility mode, do you mean once it is installed to click on the program and set it to run in compatibility mode? Thanks Larry H. Walker, PE President walker associates engineers 32 Clarksville Street | Suite 202 Paris, Texas 75460 M| 903-272-5231 lwalker@wacivil.com
    *Expert Elite*
    DarrenP
    01-23-2013 05:27 PM in reply to: lwalker
    yes
    Member
    01-23-2013 06:22 PM in reply to: lwalker
    Good idea, but it did not work for my CAD. It crashed just as fast with the changes you described. I am going to end up switching hardrives to run Windows 7 inorder to run CAD. This will be alot of work and I am not real happy about it. I am going to warn everyone I know that uses CAD, that Windows 8 and CAD are not a good mix.
