AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
CIVIL 3D 2013 RUNNING ON WINDOWS 8
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I recently upgraded my computer to run Windows 8 Pro. Everything is working great except for the grading functions in Civil 3D. All other areas function fine but when I am in a grading plan and try to do anything the program crashes and shuts down, any suggestions?
Re: CIVIL 3D 2013 RUNNING ON WINDOWS 8
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Windows 8 is not a supported OS for Civil 3D which means autodesk did not test it on windows 8 so what ever problems you run into my or may not get fixed in 2013
you can look through here for issues and workarounds other people have posted: http://forums.autodesk.com/t5/forums/searchpage/ta
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
So you are saying this problem with windows 8 and civil 3d crashing will not be fixed this year? Are they attempting to fix this?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
maybe or maybe not
windows 8 came out after civil 3d 2013 was released
may have to wait until 2014 to release for a fix
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
So how do you go about trying to get these problems fixed? Is autodesk attempting to try to help out? If so how do I get in touch with support?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I don't, since I know that C3D2013, and earlier, is not officially supported by Autodesk. Nor do I expect them to. When the next version is released, assuming it will be Win8 compliant, then I may get a new PC with Win8. In the meantime, I will continue to work without too many progam errors with my trusty Win7 and C3D 2012/2013.
If you want to submit a support request, there is a mechanism for that in the Subscription site. Not on Subscription? Then there's the web form: http://usa.autodesk.com/adsk/servlet/index?siteID=
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You won't necessarily get this issue fixed, at least not by Autodesk. There might or might not be a service pack for 2013 to address this issue.
I have had a couple clients who installed using Windows 7 Compatibility Mode and are up and running with no errors.
Also, you if you want to spend some time with it, you can test in diagnostic startup. If that works, try selective startup and one-by-one re-apply the services you turned off. Eventually you'll find one that's conflicting with grading. This could take hours.
Personally, I am doing what JeffM is doing. I'll install Win8 when Autodesk says they support it. At this point they have not said that.
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
yes
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Good idea, but it did not work for my CAD. It crashed just as fast with the changes you described. I am going to end up switching hardrives to run Windows 7 inorder to run CAD. This will be alot of work and I am not real happy about it. I am going to warn everyone I know that uses CAD, that Windows 8 and CAD are not a good mix.
