• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    bo.martin
    Accepted Solution
    C3d 2013 Structure Change
    123 Views, 2 Replies
    09-24-2012 05:50 AM
    I'm learning pipe network's....
    I need to change a structure type and I can't seem to find
    where I can change it.
    TIA
    Bo
    Please use plain text.
    Re: C3d 2013 Structure Change
    09-24-2012 06:44 AM in reply to: bo.martin
    It's easy. Click on the structure to highlight it, then right-click for the pop-up menu. On that menu, there's a command to 'Swap Part...'. It brings up the part catalogue to pick the next part to change it to. Be aware that this also updates the part description, so you may want to check that after you swap the part.
    If the pop-up menu doesn't show a 'Structure Properties...' or 'Swap Part...', there must be 2 or more items highlighted. Hit ESC a couple of times and try again.
    Windows 7 64-bit
    HP Z600 8 Gig RAM
    Civil 3D 2011
    Valued Contributor
    bo.martin
    09-24-2012 07:55 AM in reply to: ccoles
    That got it.
    You have to do it in plan view. In the profile view the swap part option wasn't there.
    Thanks!!
