• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    C3d 2010 Cogo points not in prospector
    99 Views, 4 Replies
    05-18-2012 08:37 AM
    I have an existing drawing that I have picked cogo points for survey layout about 3 weeks ago.  Now when I open the drawing the points show up on the screen, but they are not in the prospector.  Where did they go?  What do I need to do to get them back in the prospector?
    Todd
    Please use plain text.
    Re: C3d 2010 Cogo points not in prospector
    05-18-2012 09:06 AM in reply to: tbronson
    When you select one in the drawing, what does it display in the Properties Palette?
    05-18-2012 09:15 AM in reply to: tbronson
    It's an AECC_POINT.
    05-18-2012 09:46 AM in reply to: tbronson
    That is a LandDesktop point, not a C3D point. In order to display in Prospector the points must be converted to C3D points. Perhaps this was previously done and either the drawing wasn't saved or you are using a different drawing.
    05-18-2012 09:56 AM in reply to: Jeff_M
    That did the trick.  I must have created the drawing when we were using LDT without realizing it.
