• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    C3D2013 - SP1 - Pipe Cross Section Label Issues
    101 Views, 1 Replies
    02-04-2013 06:47 AM
    Thought this was fixed in SP1.
    Dreffed storm drain pipe network into corridor/cross section source drawing.
    Created sections with bands,
    Added pipe lables.
    Saved, Closed
    Reopen - NO PIPE LABELS.
    You guys got some sort of hidden weeding factor built in? or a set anchor toggles
    Been running ACAD since 1981, I NEVER install an update until the First Service Pack has been issued (+3 months) just for this reason. My fix is finally here only to find it is not.
    Install went smooth on both network and standalone machines as well as SP-1 install.
    64bit standalone
    Please use plain text.
    Product Support
    Re: C3D2013 - SP1 - Pipe Cross Section Label Issues
    02-05-2013 01:24 PM in reply to: rzbker1974
    I tested this with the Pipe Networks 3B.dwg tutorial drawing and was unable to reproduce. I labeled the pipes in section view, left some stationary, and moved some to a dragged state. After a save and reopen, lables were still present.
    Is there something specific I need to do in order to reproduce? Have you tested outside of this particular drawing/data set?
    Seth Hall
    Product Support
    GCSO - CSS - FTS
    Autodesk, Inc.
    Being Civil
    Being Civil Twitter
    Being Civil Facebook
