• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    office
    C3D2012 DGM
    170 Views, 2 Replies
    05-18-2011 02:28 AM
    I tried to create user defined contour line, but the function hides (see picture).
    This Analysis is only working by heights, anything else hides. Is there already some fix available?
    Christoph
    C3D2012
    DGM Analysis
    Win7 64bit
    HP z400 Workstation
    ATI FirePro V4800
    C3D2013
    Please use plain text.
    Product Support
    AlmasSuljevic
    Re: C3D2012 DGM
    05-18-2011 07:45 AM in reply to: office
    Hi Chritoph,
    I would suggest staring with repair of install from Control Panel. Other possibility may be a display issue. Do you see any options if you hover over the area where the options should show up?
    Almas Suljevic
    Product Support Specialist
    Autodesk Global Subscription and Support
    Please click on "Accept as Solution" if post helped you resolve the issue.
    Active Member
    office
    Re: C3D2012 DGM
    05-18-2011 08:11 AM in reply to: AlmasSuljevic
    Repair already tried, but not fixed the issue. I'm able to reproduce this on two different clients. By trying via TAB it jumps directly from the legend-options to the preview (compared with c3d2011). Some other workarounds?
    Win7 64bit
    HP z400 Workstation
    ATI FirePro V4800
    C3D2013
