• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    Re: C3D 2013 Service Pack Status
    11-20-2012 02:55 PM in reply to: fcernst
    I'm happy to see this thread has been escalated, however, I'd like to share the linked thread below that has received no response.... http://forums.autodesk.com/t5/AutoCAD-Civil-3D/AutoCAD-Civil-3D-2013-Service-Pack-gt-Please-tell-me-...
    Yes, this is still extremely unstable. No HotFix 2 did not fix a thing. (as far as my stability issues)
    Undo is still broken...
    Copy and Paste Crashes Civil 3D (but not map 3d)
    Bind crashes Civil 3D (but not map 3d)
    Autosave seems to crash civil 3D at times....
    Waiting on Windows 8 compatibility?? I hope not!! We've been dealing with an extremely unstable program since April.
    As unstable as this program is, I would think there would have been a bigger push to releases the first service pack within a few months.... An all hands on deck approach.... The ship is sinking and bucket bailing is not quite cutting it...
    Paul R. Mascaro
    CAD Supervisor | Engineering Design
    ENVIRON International Corporation
    System: Dell 6600M
    OS | MS Windows 7 64-bit SP1
    CPU | Intel Core i7 @ 2.70GHz
    RAM | 8.00 GB DDR3 1600 MHz (Dual-Channel @ 798MHz)
    Graphics | NVIDIA Quadro 5010M (4 Gig)
    Please use plain text.
    Valued Mentor
    fcernst
    11-22-2012 05:50 AM in reply to: pmascaro
    I get the following crash when exporting a pipe network to XML:
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
    *Expert Elite*
    11-22-2012 08:01 AM in reply to: fcernst
    Fred, is this with the ExportLandXML command or inside another command? Can you share the drawing this occurs in?
    I can select one, or more, networks in Prospector and export to LandXML without a hitch. So just wondering if it is a command issue or perhaps a drawing issue.
