• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    ccookusi
    C3D 2013 Profile Linetype generation
    413 Views, 5 Replies
    08-22-2012 05:23 AM
    This does not seem to be working in 2013 when the profile is a reference.
    Any ideas?
    Windows 7 Pro x64
    Civil 3D 2013 (SP1)
    Dell Precision T1650
    i7 3770
    NVIDIA Quadro 2000
    SSD Boot
    12 GB Ram
    Please use plain text.
    Valued Mentor
    LisaPohlmeyer
    Re: C3D 2013 Profile Linetype generation
    08-22-2012 11:44 AM in reply to: ccookusi
    If it helps any, I can replicate this.  Seems to work fine in 2012.
    Lisa Pohlmeyer
    Williamson Co. Dept. of Infrastructure
    Intel i7 3.33Ghz, 16Gb RAM
    Nvidia Quadro 2000D
    C3D 2012 SP3, C3D 2014
    Win 7-64
    Please mark this as the solution if it resolves your issue.
    Employee
    hgohel
    08-29-2012 01:03 PM in reply to: ccookusi
    We have filed defect 1471381 to track this.  Thank you for your report.
    Himanshu Gohel
    Autodesk, Inc
    Valued Contributor
    10-19-2012 07:34 AM in reply to: hgohel
    Has there been any resolution to this issue yet?
    Active Contributor
    11-14-2012 07:04 PM in reply to: kolk
    Profile Linetype generation will not work for "surface" profiles that are data shortcutted.
    The surface profile needs to be created in the drawing that contains the profile view.
    Its okay to dref design profiles though, jsut not surface profiles. You will also notice that surface profiles that are dreffed are static and not dynamic! Not sure if this is how autodesk intended the workflow to be though.
    Regards
    Kapanther
    Civil 3D 2013 (SP1)
    Win 7 Pro x64
    DELL Precision Workstation T3500
    Intel Xeon 3.3GHz (w3680)
    24Gb Ram
    NVIDIA Quadro 2000 (1GB)
    Employee
    hgohel
    11-16-2012 05:57 AM in reply to: bkanthergolder
    DRef surface/dynamic profiles are treated as static in the drawings in which they are referenced and that is the expected behavior. That said, if the surface is updated and references are synchronized the profile will update.
    Himanshu Gohel
    Autodesk, Inc
