• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    Re: C3D 2012 vs. C3D 2011
    04-20-2011 11:05 AM in reply to: gauss2069
    Allen, Thanks. I had a chat with Norton. Norton was kicking AutoCAD programs big time. Now I am protected with the http://www.symantec.com/norton/support/kb/web_view.jsp?wv_type=public_web&ssfromlink=true&sprt_cid=f... Happy modelling!
    Civil 3D x64 2013
    Win 7 x64
    Intel Core i7-940XM
    8 GB RAM
    Quadro FX 5000M
    Please use plain text.
    *Expert Elite*
    AllenJessup
    04-20-2011 11:07 AM in reply to: gauss2069
    You're welcome. I've has similar experiences myself with Norton.
    Allen
    Distinguished Contributor
    04-20-2011 01:19 PM in reply to: Jason.Hickey
    Jason:
    Thank you for acknowledging the request.  I do hope I'm not the only one asking for it.  I'll be the first at my company to try out and propose using whichever software does it competently first.  So far I've heard that Revit MEP + EaglePoint Site Works is close to it, although I have my doubts that it would work as seamlessly as some say....
    --Jeremy
    Distinguished Mentor
    04-20-2011 01:58 PM in reply to: jmatthei
    Speaking of object enablers, why is it that there is an object enabler install right at the end of the installation process? Is that new? Wouldn't think the object enabler is needed for the product that is being installed.
    Greg
    04-20-2011 01:59 PM in reply to: gauss2069
    My guess is it enables Revit objects to be viewed in C3D.
    Employee
    Matt.Anderson
    04-20-2011 08:27 PM in reply to: GTVic
    Greg
    The Object Enabler is installed onto Autodesk Storm and Sanitary Analysis 2012 which is installed at the tail end of the installation.
    Matthew Anderson, PE
    Business Consultant
    Global Services
    Autodesk, Inc.
    Westhills
    04-28-2011 11:08 AM in reply to: gauss2069
    Here goes. Regarding my issue earlier in this thread regarding the lag. After some back and forth and collaborating, Autodesk called me today to say there indeed was an issue that is problematic with CAD 2012. For me it was manifested by the number of layers exceeding some number. Apparently this issue manifests itself in opther ways aswell. I was advised this has gone straight to the top of the chain of command and is requiers a hotfix immedialty. So there you have it. Hotfix on the way!
    Win 7 64bit
    16 Gigs Ram
    Intel i7 870
    Quadro fx1800
    C3D 2011/2012
    ASUS Custom
    Dual 24 Phillips screens
    Active Contributor
    08-01-2011 08:36 AM in reply to: jbear0000
    I've been working with 2012 sine the box hit my desk. I notice a few things but not real big. The things I've noticed is the dtext problem when editing, I've been having some problems in the 32 bit install were I create a new layer and then try to change the color but the color want take ( only in 32 bit).
    Another thing I've noticed is some feature line/brake lines problems. The problem seems to be after I add new feature lines to an existing surface some of the existing feature line/brake line loses there effect on the surface. But note they worked and had effect on the surface prior to the newly added feature lines/brake lines. Also note these added feature lines are in a total different area of the surface so should not affect the feature lines/brake lines. So what I needed to do was explode the feature lines that no longer had effect on the surface, and then use the command “create feature lines from object”, and then add the feature line back into the surface as brake line.
    Please let me know if you have any questions etc.
    Danny
    *Expert Elite*
    Joe-Bouza
    08-01-2011 11:40 AM in reply to: civilspace
    Isn't it ironic that all the fruit is out-on-the-limb. :smileywink:
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
