• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    C3D 2012 Reports Tools Problem: "Execute File Is Not Exist"
    136 Views, 8 Replies
    06-13-2012 06:13 AM
    I am trying to run a parcel area report generator, and I get the above error message, along with the path \xsl\Parcel_Area.xsl and an advisory to reinstall the program.
    I think it is pointing to the full path location of C:\ProgramData\Autodesk\C3D 2012\enu\Data\Reports\xsl.
    The file (Parcel_Areas.xsl) exists in this location.
    NONE of the parcel reports that I tried to execute work - they all return the same grammtically painful error message.
    Please advise. Reinstalling the program involves getting IT involved, which is always painful.
    dr
    Please use plain text.
    Product Support
    Re: C3D 2012 Reports Tools Problem: "Execute File Is Not Exist"
    06-14-2012 08:25 AM in reply to: davidrenaud3020
    Do any of the other reports work?
    What path do you have listed in the Toolbox Editor?
    Seth Hall
    Product Support
    GCSO - CSS - FTS
    Being Civil
    Being Civil Twitter
    Being Civil Facebook
    Active Contributor
    06-15-2012 06:10 AM in reply to: SethHall
    Thanks, Seth,
    I checked the path and directed it to the file in C:\ProgramData\Autodesk\C3D 2012\enu\Data\Reports\xsl\Parcel_Area.xsl. Still no joy. No other parcel reports work either. I haven't tried anything else.
    dr
    Active Contributor
    06-15-2012 06:12 AM in reply to: davidrenaud3020
    OK, wait!
    If I execute the routine from the Toolbox Report Editor it works. But if I execute it from just the Toolbox tab on the prospector, it doesn't. Riddle me that.
    dr
    Active Contributor
    06-15-2012 06:17 AM in reply to: davidrenaud3020
    ****, spoke too soon. what I get when I execute from the report editor is the same LandXML dialog that I get under the File pulldown menu. I was able to make this work by unchecking all the alignemnts and corridors and such, but something is broken.
    Product Support
    06-15-2012 06:28 AM in reply to: davidrenaud3020
    If none of the reports are working I would suspect a bad install. Did you eventually get it to work, or did I miss that in your last few posts?
    Seth Hall
    Product Support
    GCSO - CSS - FTS
    Being Civil
    Being Civil Twitter
    Distinguished Contributor
    d_reno
    06-15-2012 06:50 AM in reply to: davidrenaud3020
    No, it did not work properly, I don't think.
    If I execute from Toolspace>Toolbox>Reports Manager>{arcel>Area_Report, I get the Subject eror message.
    If I execute from Toolbox Editor>Reports Manager>Parcel>Area_Report, I get the same LandXML export dialog that I get from the File pulldown menu: File>Export>Export to LandXML.
    I will ask my IT department to do a reinstall, I guess.
    thanks for your help.
    David Renaud, RLS
    C3D 2012 on 64bit Win 7 all up to date
    Dell Precision 7core 8GB RAM
    NVIDIA Quadro FX 1800M
    LDT/C3D user since release 12
    Product Support
    06-15-2012 06:55 AM in reply to: d_reno
    One other thing you may try is RUN AS ADMINISTRATOR and make sure you have full access to where the reports files are located.
    Seth Hall
    Product Support
    GCSO - CSS - FTS
    Being Civil
    Being Civil Twitter
    Active Contributor
    06-15-2012 08:11 AM in reply to: SethHall
    I will try, but I already have admin and write priveleges. I will report back when I get a chance to chekc.
