• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    BtimmermanMMS
    Accepted Solution
    C3D 2011 - Rotate Points/Symbols but NOT Labels
    386 Views, 11 Replies
    01-23-2012 10:02 AM
    I have tried to follow a few of the other posts about getting points to rotate, but have the labels be independent of the symbols when rotating. I have my label style set to view under the orientation reference, but still have the labels being rotated while in model space to the rotation angle of the point (using grips).
    I would simply like to be able to grip edit my symbol to rotate it accordingly.
    For whatever reason - C3D 2011 is giving me grief with this simple task. Why?
    Please use plain text.
    *Expert Elite*
    sboon
    Re: C3D 2011 - Rotate Points/Symbols but NOT Labels
    01-23-2012 11:20 AM in reply to: BtimmermanMMS
    Based on your description it should be working correctly.
    Can you post the drawing?  If not then maybe just post your template drawing so that we can look at your styles.
    BtimmermanMMS
    01-23-2012 11:43 AM in reply to: sboon
    I"ve left the drawing zoomed into the symbols that I've been trying to rotate. Storm Intake and a power pole to the right side of intake. It was a simple selection/grip edit/rotate/ and then the issue with label rotating with symbol. Confused...
    Thanks for the assistance.
    Product Support
    01-23-2012 11:46 AM in reply to: BtimmermanMMS
    BtimmermanMMS
    01-23-2012 11:59 AM in reply to: SethHall
    Not sure why it isn't working, but I've tried with View and WCS and the labels still rotate with marker. What the heck am I missing? See drawing I have attached to previous post.
    *Expert Elite*
    sboon
    01-23-2012 12:07 PM in reply to: BtimmermanMMS
    The problem might be in how you're selecting the point for editing.
    When I select one of your points I get two cyan grips that pop up - a diamond shape centered on the symbol and a square one above that.  If I hover over the square grip then I get a tooltip popup that allows me to move and rotate the label, but not the symbol.  If I hover over the diamond grip then I get another popup that includes options for rotating just the symbol or both the symbol and label.
    I'm doing this in 2012, and I don't know if 2011 uses the same method or it may be the older style of control like Seth's blog post.
    BtimmermanMMS
    01-23-2012 12:36 PM in reply to: sboon
    Don't see that in C3D 2011 - must be a new feature built into 2012.
    Product Support
    01-23-2012 12:42 PM in reply to: BtimmermanMMS
    I get "drawing file is not valid" when attempting to open your file.
    Additionally, I believe the new features in 2012 allow this to be accomplished. My blog post was written in 2010 I believe. Maybe try to go through the blog post again, and see if that helps.
    Seth Hall
    Product Support
    GCSO - CSS - FTS
    Autodesk, Inc.
    Being Civil
    Being Civil Twitter
    Being Civil Facebook
    Valued Mentor
    01-23-2012 12:45 PM in reply to: BtimmermanMMS
    The "Orientation Reference" of label style "MMS Standard" is set to Object.  Set it to "view" and it will rotate the way you want.
    before:
    after:
    BtimmermanMMS
    01-23-2012 12:48 PM in reply to: SethHall
    Hmmm...Anyone else having issues with getting that file to Open?
    I'm attaching a zip file done from the eTransmit in C3D 2011. I did an open with file and no errors on my end.
    Anyway...for what it is worth - here is the eTransmit file (Zip file)
