• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    ***Guru
    C3D 2010 SP3 posted
    2002 Views, 36 Replies
    07-19-2010 04:39 PM
    Surprise!
    There's a new SP for C3D 2010:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15407692&linkID=9240697&CMP=OTC-RSS...
    Looks like Autodesk is finally starting to give us more than one year of support for this program!
    Sinc
    Distinguished Mentor
    Re: C3D 2010 SP3 posted
    07-20-2010 07:48 AM in reply to: Sinc
    Ok, they fixed a few things, what did they break with this one???
    *Pro
    07-20-2010 09:50 AM in reply to: Sindarin
    Must be a late April Fool's joke....refuses to install.
    Active Member
    07-20-2010 10:55 AM in reply to: Sinc
    Its the Subscription Advantage Pack. It installs fine on SP2 but not with SAP added.
    *Pro
    07-20-2010 11:22 AM in reply to: mebert02
    Thanks, I had wondered about that.
    So, I guess this part of the readme needs to be changed:
    <quote>
     If you intend to apply the AutoCAD Civil 2010 Subscription Advantage Pack to your installation of AutoCAD Civil 3D, you must do so before applying AutoCAD Civil 3D Update 3. Attempts to apply the Subscription Advantage Pack after application of AutoCAD Civil 3D Update 3 will fail.
    </quote>
    To add:
    Attempts to apply the patch after installing the SAP will also fail, so don't do that!
    Hmmm....
    *Pro
    07-20-2010 02:13 PM in reply to: Sinc
    I had this same error and Autodesk suggested that I may have an old SAP, which I did.  You need to download the latest SAP and  remove C3D and install it again using the latest SAP.  I have not tried this yet, but that's what adsk suggested.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    07-20-2010 02:15 PM in reply to: mathewk
    Autodesk should change their name to "Time wasting products/updates, and programs that never work as expected"
    Active Member
    07-20-2010 02:18 PM in reply to: mathewk
    That wild imply that there was an update to the SAP. If so I don't recall any kind of notification or indication on the SAP download page.
    Active Member
    07-20-2010 02:19 PM in reply to: mebert02
    Should have been 'would' imply.
    *Pro
    07-20-2010 02:38 PM in reply to: mebert02
    I have an older SAP that what is there now, so nevertheless...try downloading it again if you are getting this message.
    Matt Kolberg
