AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Bug contour
- Highlight
- Email to a Friend
- Report Inappropriate Content
If I have drawn a polyline (pol1) under other closed polyline to use as a contour, even if you select closed polyline (pol2), the program uses the polyline below.(pol1).
Quad Core Intel i7 3770-cpu 3.40Ghz.
32gb RAM 1600 Mhz.
nVidia Quadro 2000.
Win 7 Pro 64bit
Re: Bug contour
- Highlight
- Email to a Friend
This bug succes in Civil 3D 2012 SP1
32gb RAM 1600 Mhz.
nVidia Quadro 2000.
Win 7 Pro 64bit
Re: Bug contour
- Highlight
- Email to a Friend
Try to toggle between POL1/POL2 by pressing CTRL during the selection.
Re: Bug contour
- Highlight
- Email to a Friend
that does not work.
I have the polyline (pol2) top.
The program should not take the polyline below if I haveselected that.
32gb RAM 1600 Mhz.
nVidia Quadro 2000.
Win 7 Pro 64bit
Re: Bug contour
- Highlight
- Email to a Friend
I'm not familiar with cntrl, but tapping the tab key with cross hair over will cycle through the entities to be sure of selection
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Re: Bug contour
- Highlight
- Email to a Friend
excuse me, i refer to "boundaries" not "contours"
32gb RAM 1600 Mhz.
nVidia Quadro 2000.
Win 7 Pro 64bit
Re: Bug contour
- Highlight
- Email to a Friend
Just to clarify, when you talk about the polyline line being "below" the other one, are you referring to the elevations of the polylines? If so, AutoCAD does not look at the elevations of the objects when selecting them, but it will look at the draw order. Select the one you want to be "below" the other, right click, choose "Display Order" and then "Send to back" (or something along those lines).
Hope this helps (if that is indeed what the issue is).
Re: Bug contour
- Highlight
- Email to a Friend
The last object drawn, by default, stays on top of the display list: if you wanna select something below, you should use the CTRL toggle mode or, alternatively, press simultaneously SHIFT-SPACE
Re: Bug contour
- Highlight
- Email to a Friend
If you're on 2012, at the bottom of your screen is Selection Cycling (right end of the toggle buttons.) Turn that on. Now when you select, you'll get a dialog that lists the possible choices. Pick the one you want and AutoCAD will make that your selection.
If you're on 2010 down to 2008 (I think) use Shift+Spacebar to turn on selection cycling. You won't get a dialog. In earlier versions, use Ctrl to turn on Selection Cycling.
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Re: Bug contour
- Highlight
- Email to a Friend
One more method.
Select both with a crossing window, type R into the command line and hit enter. This allows you to remove objects from the selection set. Select the pline on top (last drawn) and hit enter again. This first drawn is added and the last drawn is not.
C3D 2012, RD 2012
Win 7 64, Core i7,
6 GB RAM, Quadro FX 1700
