• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Civil 3D
    Active Contributor
    normans
    Accepted Solution
    Broken refs
    243 Views, 6 Replies
    11-29-2012 12:37 PM
    Any suggestions on tracking down and eliminating the cause of the msg:
    Drawing contains a broken reference - Source AeccDbSurfaceTin '2008 contours' could not be found in drawing S:\Phase 276-Closure Documents for the TIF\drawings\Draft design\build\2008 contours.dwg
    I don't see any xref or data shortcuts in this drawing.  The message appears in the Event panorama when I xref this drawing from another. Must be old reference that is hanging out somewhere?
    Any help much appreciated.
    Civil 3D 2013 SP 1
    Dell Precision T5600
    Win 7 Professional 64 bit
    Intel Xeon @ 2.0 GHz
    16 GB RAM :smileywink:
    Please use plain text.
    Active Contributor
    normans
    Re: Broken refs
    11-29-2012 01:37 PM in reply to: normans
    BTW I'm using C3D 2012 and not wanting to fix the broken aspect of the issue - would rather delete that reference if I could find it. It somehow creeped into this drawing. More than likely was left over from client's drawing?
    I also see reference to the 2008 contours in the Sample more sources window for the sample lines. If I could find it I would do something magical like right-clicking and selecting Delete!
    Thanks again!
    Civil 3D 2013 SP 1
    *Pro
    Re: Broken refs
    11-29-2012 01:44 PM in reply to: normans
    maybe empty the drawing and post it.    maybe someone can figure out how to clean it.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    Valued Mentor
    Re: Broken refs
    11-30-2012 06:41 AM in reply to: normans
    Sounds like a broken data shortcut reference to me since it gives you a Civil3D object type "AeccDbSurfaceTin", not a filename.
    I'm assuming it doesn't show up in prospector once you get the file open where you could delete it, correct?
    Is it possible to post the file?
    Mike Robertson
    FDOT
    Mike Robertson
    FL. Dept. of Transportation
    CADD Applications Developer
    HPxw4600 Workstation
    Core 2 Duo 2.33ghz, 8gb RAM
    nVidia Quadro FX1700
    Win7 64bit
    Valued Contributor
    C3D_TomR
    Re: Broken refs
    11-30-2012 12:12 PM in reply to: normans
    I don't know if it will help, but here are two suggestions:
    • Try an Audit or recover the drawing. Sometimes even though it says 0 found 0 fixed, there's still sometihing fixed.
    • Thaw and make all layers visible. Execute the erase command. When prompted to select objects, type all at the command line then press enter one time. When prompted to continue selecting objects, type r and press enter. You'll then be prompted to select objects to remove. Select all the visible objects on the screen to remove them from the selection set. Press enter after selecting everything to remove and whatever remains, if it can be erased, will be.
    Be careful with this method of erasing objects though.
    Instead of erasing the objects, I'll sometimes use this same selection method with the CTRL+C  then CTRL+V commands to copy the objects to a blank drawing. This will show me what layers, blocks, linetypes, etc. are created in the blank drawing.
    --Tommie
    Active Contributor
    normans
    Re: Broken refs
    12-04-2012 08:35 AM in reply to: C3D_TomR
    Thanks for the suggestions. I had been pulled off the project and now can't duplicate but when I see the msg again I will post again. I will keep your suggestions in mind though. I appreciate the assistance.
    I will struggle on.......
    Civil 3D 2013 SP 1
    Distinguished Contributor
    Re: Broken refs
    12-28-2012 08:54 AM in reply to: normans
    I had a similar situation here. I xrefed my design profile view into my Plan & Profile sheet and kept getting a similar error to the original post. Everything looked fine but one of the profiles associated with the surface wasn't displaying. Tried the auditing, found errors but still no profile when xrefed. It displayed fine when the xref is opened.
    My fix was to change the profile to Static and it then displayed in both drawings and I didn't get the error. That led to the linetype issue with static profiles so I changed it back to Dynamic. It's now displayed in both drawings and there has been no error. Fingers crossed that it stays this way.
    Civil 3D 2012
    Windows 7 Pro (64bit)
    Intel Xeon W5580 @3.20GHz
    12gig RAM
    NVIDIA Quadro 600
