• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Bounded Surface Report
    131 Views, 3 Replies
    10-02-2012 09:07 PM
    Is there a way to generate a volume report for a bounded volume surface?
    Don
    Please use plain text.
    neilyj
    Re: Bounded Surface Report
    10-03-2012 04:36 AM in reply to: DonHayter7843
    I think only if you have the Volumes Dashboard - subscription in 2012, standard in 2013
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    BrianHailey
    10-03-2012 08:24 AM in reply to: DonHayter7843
    If you don't have the Volumes Dashboard (i.e. 2011 or earlier) you can use the Bounded Volumes command. In order to use the command you'll need a volume surface and a polyline representing the area of interest.
    http://screencast.com/t/rb071TsfLge
    neilyj
    10-03-2012 08:37 AM in reply to: BrianHailey
    I assumed the OP wanted a real report rather than a command line cut and paste which is the only output available from this method:smileywink:
    neilyj
