• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Blocks for Description Keys
    80 Views, 1 Replies
    01-10-2013 01:07 PM
    Hello All,
    Civil 3D Newbie here.
    I am making a directory full of the blocks we will use for the description key file to use. My understanding is that all of these blocks (manholes, hydrants, trees...etc) should be on layer "0" and of standard size. Manholes should be about 3' in diameter, transformer pads around 4' square....etc. Essentially, 1 = 1 true scale.
    Is this true?
    Thanks Much,
    W.S. McDowall
    Columbus, Ohio
    Please use plain text.
    *Pro
    Re: Blocks for Description Keys
    01-10-2013 01:18 PM in reply to: snowczar
    with objects scaled by the drawing scale it really doesn't matter what size the initial block is.   The point is inserted into a box that is for instance 0.1' high in paper space.   once you bring the point into a 40 scale drawing you have to play with the scaling until you get it close to the size you need.    then once it works for one scale it will work for all scales.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
