• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Block constraints. How do I hold a line to txt length?
    80 Views, 2 Replies
    01-15-2013 09:00 AM
    I am using Civil3D 2012 SP 2.
    I am creating a block for my details. I want to be able to title my block and the the line under my txt will change it's length based on the lenght of the text. I keep playing with the constraints, but I haven't found one that is doing what I want.
    AutoCAD Civil 3D 2012 SP2
    Windows 7 (64)
    Please use plain text.
    *Expert Elite*
    Re: Block constraints. How do I hold a line to txt length?
    01-15-2013 09:30 AM in reply to: jamesbarnett
    One solution would be to underline the text.
    When typing text to be underlined, preface it with %%U. For example: %%uTitle will be Title. Changing the text will change the underline.
    Another way would be to use a Civil 3D Note object (but it can't be part of a block) and underline or create a line component that uses start and end of the text component as its start and end points.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Active Contributor
    01-15-2013 09:50 AM in reply to: tcorey
    I thought of those options, but I kind of wanted the line a different color and I want to do it all in a block so it will be seemless.
    Windows 7 (64)
