• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    ruipfbarreiros
    Re: Best way to edit a pipe network layout
    07-05-2012 11:32 AM in reply to: castled071049
    I meant that the with the alignment I can only control the network I will later insert horizontally.
    To edit the pipes vertically, I must have already created the network.
    Right?
    Using:
    - Autocad 2012
    - Autocad Civil 3D 2012
    Please use plain text.
    Valued Mentor
    07-05-2012 11:33 AM in reply to: ruipfbarreiros
    Exactly right.
    Valued Contributor
    csevers
    01-30-2013 03:18 PM in reply to: castled071049
    The biggest problem I run into is having to re-enter my pipe inverts every time I change my layout in plan view. I wish there was a way that when I move the nodes in plan view I wouldnt lose my inverts in my profile. It's very annoying because my profile views typically only show between El. 700 and 730 (30' or so) and when I move my nodes in plan, the pipes drop  off of the profile view entirely and I have to re-enter my inverts via pipe properties just to get them back on the profile view for adjustment. There has to be a better way.
    Joe-Bouza
    01-30-2013 03:54 PM in reply to: ruipfbarreiros
    for me the alignments from part has worked fine, editing postion after the fact nevergot in the waywhen I grip the structure I grip the pi at the same time. the pipes and the profile view change with the plan edits. The vertical edits, eh... Its engineering : stuff happens.
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Distinguished Contributor
    01-31-2013 01:42 AM in reply to: ruipfbarreiros
    Just my small contribution to the whole discussion. My personal opinion is that, regarding pipes, concept of alignments (way how it is now implemented) is wrong or not effective.
    If you have just pipe network, I would like to draw profiles without alignments, just through sequence of sections and nodes. And, yes, if I would like to edit something, not to take care about editing both network elements and alignments to update profile view.
    Drazen
