AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Bearing and distance info needed between two points
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am a very recent convert to Civil 3d (within the last week, in fact!) -- I have been using LDD for many, many years. As a surveyor, one of the routines that I most use is determining the bearing and distance between two points. I have not been able to find a method to accomplish this task in a simple and speedy way in Civil 3d. Drawing a line between the two points in question and then listing the line's properties (and then having to delete the line when finished) seems like a waste of steps, especially when compared to what it took in LDD. The "Help" section does not address this problem, so I'm hoping to get some feedback from this forum.
Thank you for your input!
Re: Bearing and distance info needed between two points
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think most people use the DIST command. There's also the Inquiry tool, although that's not as accessible as the DIST command.
I prefer the PTINV command. It's only available in the Sincpac-C3D, a third-party add-on, but it gives much more useful output than the DIST command, including both 2D and 3D distances between your pick points.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you for your reply. I have tried the "DIST" command, but it only returns a horizontal measurement between two points -- it unfortunatelly doesn't provide a bearing to go along with the distance.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Are you looking for the Brng & dist between 2 AECC points of just any 2 points you can pick in AutoCAD?
Allen
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You can just the Inquiry Tool and select the Point1 and Point2 coordinates from anything you can snap to.
See Attached image.
But the best way to get an inverse between 2 points is the use he CGLIST command. You can list the info on a line or curve by selecting the object or you can select Points and snap to end, mid, center points or any other point you can usually snap to. You can also us the Transparent Commands to snap to AECC points by name or number or Select the Point Object.
Allen
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Allen:
This problem involves two aecc points...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Allen -- I'll give it a try.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Point Inverse through the Inquiry Tool is the best way I've found to accomplish what you're trying to do. One thing that still baffles me about C3D though is it's inability to just place a label between two points in space and not be tied to a line.....
Erlandsen
Civil3d 2012
Intel Core 2 Quad 2.66GHz
Win7 64bit
Quadro FX1700 (Driver 265.70)
8GB RAM
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for your reply. From the feedback that I've heard from other surveyors who have migrated (or rather forced!) to Civil 3d, this software does not lend itself very well to the needs of surveyors. Or maybe it's just that we surveyors are a difficult bunch of SOB's who are hard to please! LOL!!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Well, that's a fact! We are a bunch that's fairly resistant to change, but that one issue has kept us from migrating for the last 4-5 years. As I'm sure you know....that's a much needed feature in the surveying world! Without it, plats and ROS's are very difficult to draft.
Erlandsen
Civil3d 2012
Win7 64bit
8GB RAM
