• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    JamaL9722060
    “Basic assembly” is not drawn correctly in the section view,
    132 Views, 5 Replies
    10-16-2012 02:42 PM
    In the screenshot below, the “Basic assembly” is not drawn correctly in relation to the existing ground.
    What might be the reason that it is not closed with the existing ground?
    Thank you for the help,
    Best
    Jamal
    Jamal NUMAN, GIS and Civil Engineer, MSc
    e-mail: JamaL9722060@yahoo.com
    P.O.Box: 731, Ramallah, West Bank, Palestine.
    Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
    Windows 7 (Ultimate 64 bits),
    Firefox 20.0,
    Kaspersky 2013.
    Please use plain text.
    Valued Mentor
    LeafRiders
    Re: “Basic assembly” is not drawn correctly in the section view,
    10-16-2012 04:27 PM in reply to: JamaL9722060
    To me it looks like a target isn't set properly in your Corridor Properties. Either that or there is a gap in your surface which it doesn't look like is the problem.
    *Expert Elite*
    10-17-2012 07:48 AM in reply to: JamaL9722060
    Your surface isn't wide enough at that station.  You're using, say, a 3:1 slope and that slope will not intersect the surface because there is not enough surface.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    JamaL9722060
    10-17-2012 02:24 PM in reply to: mathewk
    Thank you guys for the answer. This is quite useful.
    Does this affect the calculations of fill and cut then? What might other consequences be?
    Firefox 20.0,
    Kaspersky 2013.
    *Expert Elite*
    10-17-2012 02:39 PM in reply to: JamaL9722060
    It will absolutely affect your volumes because there would be nothing to calculate at that station.  You NEED to make your surface larger in that area.  Either get more survey or make stuff up (fudge).
    Matt Kolberg
    JamaL9722060
    10-19-2012 01:46 AM in reply to: mathewk
    Many thanks for the valuable answers.
    I tried to modify the slops of the “assembly” but sounds that the “sections” doesn’t repond!
    Is there a particular way to update them according to the change in the “assembly”?
    Firefox 20.0,
    Kaspersky 2013.
