• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    BLURRED IMAGE PLOTS
    606 Views, 8 Replies
    10-19-2007 12:43 PM
    I started having a problem plotting to an HP Design Jet 1055CM with 2008. Everything on the sheet plots OK, except for image files (USGS Topo Maps, Aerial Photo, etc), they come out blurred.
    Please use plain text.
    Distinguished Contributor
    Re: BLURRED IMAGE PLOTS
    10-19-2007 01:37 PM in reply to: stevenwhite
    If you plot to a DWF or PDF then to the plotter, are they also blurred? This will help determine if it is Civil 3D causing the problem or your plotter driver/plotter.
    Active Member
    10-22-2007 08:38 AM in reply to: stevenwhite
    Yes, If I plot the image from Microsoft Document Imaging ArcMap 9.1 or Adobe, they all come out clean. They only blurr when plotting from AutoCAD.
    *James Murphy
    10-22-2007 09:06 AM in reply to: stevenwhite
    How are you attaching the images? If you are using the Data Connect and
    "attaching" then it's a know bug, using the Map image attach should work.
    Murph
    The world is not FLAT so why is your GIS data?
    http://map3d.wordpress.com
    wrote in message news:5757026@discussion.autodesk.com...
    Active Member
    10-22-2007 09:30 AM in reply to: stevenwhite
    I've attached them using standard image insert, Map Image Insert and Data Connect raster connect in AutoCad, I've tried all three in Civil 3D and Raster Design, same problem. Only the image blurrs everthing else (lines, circle,etc) come out clear.
    New Member
    10-22-2007 12:28 PM in reply to: stevenwhite
    You can check your Plotter Configuration Settings. The Raster Graphics my need to be turned up. See Attached Image
    Active Member
    10-22-2007 01:47 PM in reply to: stevenwhite
    Already tried, didn't work. Thanks
    Active Member
    10-22-2007 01:48 PM in reply to: stevenwhite
    Active Member
    10-23-2007 09:00 AM in reply to: stevenwhite
    Problem fixed by using Map Image insert, instead of using DATA CONNECT Raster Image, it blurrs the Image.
