AutoCAD Civil 3D
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
BLURRED IMAGE PLOTS
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
602 Views, 8 Replies
10-19-2007 12:43 PM
I started having a problem plotting to an HP Design Jet 1055CM with 2008. Everything on the sheet plots OK, except for image files (USGS Topo Maps, Aerial Photo, etc), they come out blurred.
Re: BLURRED IMAGE PLOTS
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-19-2007 01:37 PM in reply to:
stevenwhite
If you plot to a DWF or PDF then to the plotter, are they also blurred? This will help determine if it is Civil 3D causing the problem or your plotter driver/plotter.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-22-2007 08:38 AM in reply to:
stevenwhite
Yes, If I plot the image from Microsoft Document Imaging ArcMap 9.1 or Adobe, they all come out clean. They only blurr when plotting from AutoCAD.
*James Murphy
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-22-2007 09:06 AM in reply to:
stevenwhite
How are you attaching the images? If you are using the Data Connect and
"attaching" then it's a know bug, using the Map image attach should work.
Murph
The world is not FLAT so why is your GIS data?
http://map3d.wordpress.com
wrote in message news:5757026@discussion.autodesk.com...
Murph
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-22-2007 09:30 AM in reply to:
stevenwhite
I've attached them using standard image insert, Map Image Insert and Data Connect raster connect in AutoCad, I've tried all three in Civil 3D and Raster Design, same problem. Only the image blurrs everthing else (lines, circle,etc) come out clear.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-22-2007 12:28 PM in reply to:
stevenwhite
You can check your Plotter Configuration Settings. The Raster Graphics my need to be turned up. See Attached Image
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-22-2007 01:47 PM in reply to:
stevenwhite
Already tried, didn't work. Thanks
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-22-2007 01:48 PM in reply to:
stevenwhite
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-23-2007 09:00 AM in reply to:
stevenwhite
Problem fixed by using Map Image insert, instead of using DATA CONNECT Raster Image, it blurrs the Image.
