• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    lee_maverick
    Accepted Solution
    Axis Title Text Background Mask
    289 Views, 5 Replies
    11-15-2011 10:32 AM
    I would like to add a background mask to my Axis Title Text. Anyone know how to do it or if it can be done?
    Please use plain text.
    *Pro
    Re: Axis Title Text Background Mask
    11-15-2011 12:45 PM in reply to: lee_maverick
    there is nothing provided in the style to do this.
    maybe use the title text to give you the number and then type over it with normal text using the same style and height and then text mask the normal text.
    and display order it higher than the profile view.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    Valued Mentor
    gjrcmb
    11-15-2011 01:01 PM in reply to: dgordon
    I am unable to find a way to apply text masking to the Axis Title Text that is part of a Profile View Style.  The Axis Title Text is apparently not a separate style, so you only have access to the Text Component Editor for changing the text itself and not the Layout tab as you would see with Label Styles were you could apply masking to the text component.
    However, with that in mind I was able to create a Label Style under Profile View > Station Elevation, where I did the following:
    * Create a Text component on the Layout tab within the new label style.
    * For the text component under the Border section, set the Border visibility to False and Background Mask to True.
    * Select the ellipsis next to go into the Text Component Editor.
    * Add a Property for Station Value with the settings you want, but do not include any elevation properties.
    * Also probably need to adjust the rotation and offset values for the text back on the Layout tab.
    After you create the Style you can add a Profile View Station Elevation label, where you can select or type in a Station and elevation.  Only the Station gets labeled if you setup your style correctly, but of coarse the position of the label will be based on your input.
    While this is obviously not as convenient as an option to mask the Axis Title Text through its own style settings, it was the only thing I could come up with.
    Active Member
    lee_maverick
    11-15-2011 03:54 PM in reply to: gjrcmb
    Great Idea Thanks for the Help:smileyhappy:
    Valued Mentor
    gjrcmb
    11-15-2011 05:47 PM in reply to: lee_maverick
    You're welcome.  Looks good!  Glad I could help.
    New Member
    11-28-2012 10:14 AM in reply to: lee_maverick
    I have a similar issue with section views and applied a similar solution to the one listed here.  I created a station offset label and dropped it over the horizontal axis offsets that were being impacted.  However, has anyone created a more elligant solution over the last year?
